Coolant sensor leaking, what is the sensor?
I have a 2003 Super Duty 7.3l. I have a sensor located directly behind the idler pulley that is leaking coolant (all over my belt). I purchased a coolant temp sensor from NAPA, but that is not it. It is bigger and a two prong sensor. If that sensor is on top of the engine and right in front of the fuel filter, this sensor is wyed into it on the harness. This sensor is not screwed into the block, but into a piece of tubing. Does anyone know what this sensor is and what the Ford or NAPA part number is? NAPA cannot tell me what the sensor is, maybe they do not sell it.
Thanks
Thanks
Thanks
Thanks
The coolant temp sensor goes right into the water pump.
I replaced mine a few months ago from O'Reilly Auto Parts. Here is a link to the one I have:
O'Reilly Auto Parts - Results for Shopping Search
EBP sensor is in this pic.
I could not see the pic you sent. I will try and post one tomorrow. To answer your question, they sold me a coolant temp sensor. I have coolant leaking, i believe from what you are saying is the ebp sensor. The truck runs perfect, i just noticed the leak a few days ago.
Glad it's an easy fix. Thanks for getting back to us. Return often, you will learn a ton about the 7.3.
Commander_Chaos
02-05-2014 08:34 PM
TimmyAbrams
23
06-14-2011 10:41 AM
bulletpruf
1999 to 2016 Super Duty
10-11-2010 04:10 PM
