Virginia Chapter Join Chapter, Leader:
460 question
Old 11-04-2008, 11:42 AM
darrenmuncy's Avatar
darrenmuncy
darrenmuncy is offline
Unhappy 460 question
Hi Guys I have a 1974 f100 with original 460 that has been gone through.
the question i have is what is the total advance 20deg btdc?
my setup is as follows stock bottom and heads Eldibrock preformer plus cam with stock timing chain.
stock manifolds 2&1/2 exhaust with procomp non vacume advance distributor.it has new stock motorcraft carb.
the issue i have is it dosent smooth out til around 3000 rpms it also backfires ? any help would be greatly appreciated.
Old 11-05-2008, 01:11 AM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is online now
Received 2,703 Likes on 1,316 Posts
I have my 466 set at 9* BTDC w/o the vaccum advance hooked up.
Old 11-05-2008, 05:37 AM
darrenmuncy
Question Thanks but i was looking for total mecnanical advance
Thank you for the base advance BTDC at idle I'm looking for total mechanical advance at 3000 rpms.
Old 11-14-2008, 01:54 PM
kjett's Avatar
kjett
kjett is offline
It should be around 10* BTDC at idle, and depending on your cam, and ignition, it should be at around 34* of total advance, give or take a few degrees.
