Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 11-22-2008, 04:16 AM
rjrapp85 rjrapp85 is offline
Garage is empty, add now
rjrapp85 is starting off with a positive reputation.
Check Transmission Fluid Level
I just purchased a slightly used 2008 Ford Expedition Eddie Bauer 4 X 4. Can anyone tell me how to check the transmission fluid level? There is no dipstick, and the manual simply says the trans is "factory filled" and doesn't need to be checked.
Also, what about checking the fluid level in the transfer case? Anyone know the capacity of the transfer case, and the type of fluid to use? I assume changing the transfer case fluid is a pretty simple job.
Thanks in advance for any insights you can offer!
  #2 (permalink)
Old 11-23-2008, 10:41 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
No, no dipstick on the tranny. I guess if it don't leak, it's full!
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
Tags
2007, 2008, 2009, change, check, checking, dipstick, expedition, fluid, ford, level, levels, lincoln, navigator, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
