1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Anti Theft system question
Old 11-21-2008, 11:28 PM
tallguyorama's Avatar
tallguyorama
tallguyorama is offline
My 2000 Expedition anti theft system was set off and I can not start the vehicle up. I have no idea what the procedure is. Any help?
Old 11-22-2008, 08:02 AM
ExpySport's Avatar
ExpySport
ExpySport is offline
Is this the factory system or an aftermarket system?
Old 11-22-2008, 10:35 AM
tallguyorama
Ford Expedition Alarm
I believe it is the factory system. The only equipment I received was the key FOB and key.
Old 11-22-2008, 11:26 AM
ExpySport's Avatar
ExpySport
I went to the Ford website and pulled up the owner's manual for your 2000 Expedition. Went to the anti-theft section and here is what it said (lots to read)...
SECURILOCK
Y PASSIVE ANTI-THEFT SYSTEM
Your vehicle is equipped with a coded-key anti-theft system. Only the
correct key
will be able to start your vehicle. If your keys are lost or
stolen, you must take your vehicle to your dealership for key
reprogramming.
This system provides an advanced level of vehicle theft protection. Your
vehicle’s engine can only be started with the two coded keys provided
with your vehicle. Each time you start your vehicle, the coded key is
read by the anti-theft system. If the key identification code matches the
code stored in the anti-theft system, the vehicle’s engine is allowed to
start. If the key identification code does not match the code stored in
the system or if a coded key is not detected (vehicle theft situation), the
vehicle’s engine will not operate.
If there is any anti-theft problem with your vehicle, ensure
ALL coded
keys
for that vehicle are brought to the dealership, to aid in
troubleshooting.
The SecuriLock
y passive anti-theft system is not compatible with
aftermarket remote start systems. Use of these systems may result in
vehicle starting problems and a loss of security protection. Large metallic
objects, electronic devices on the key chain that can be used to purchase
gasoline or similar items, or a second key on the same key ring as the
PATS ignition key may cause vehicle starting concern and record DTC’s
under certain conditions. If present, you need to keep these objects from
touching the PATS ignition key while starting the engine. These objects
and devices cannot damage the PATS ignition key, but can cause a
momentary concern if they are too close to the key during engine start.
If a problem occurs, turn ignition OFF and restart the engine with all
other objects on the key ring held away from the ignition key. Check to
make sure the encoded ignition key is an approved Ford encoded
ignition key.
Spare coded keys can be purchased from your dealership and
programmed to your anti-theft system. Refer to
Programming spare
SecuriLock
y keys for more information.
If one or both of your coded keys are lost or stolen and you want to
ensure the lost or stolen key will not operate your vehicle, bring your
vehicle and all available coded keys to your dealership for reinitialization.
Theft indicator
The theft indicator in the instrument cluster will operate as follows:
²
When the ignition is OFF, the theft indicator will flash briefly every
two seconds to indicate the anti-theft system is protecting your
vehicle.
²
When the ignition is turned to ON or START, the theft indicator will
light for three seconds and then go out. If the theft indicator stays on
for an extended period of time or flashes rapidly, have the system
serviced by your dealership or a qualified technician.
Programming spare SecuriLock
Y keys
programmed to your anti-theft system (up to a total of eight keys). Your
dealership can program your new coded key(s) to your vehicle or you
can do it yourself using the following simple procedure. To program a
new coded key yourself, you will need two previously programmed coded
keys (keys that already operate your vehicle’s engine). If two previously
programmed coded keys are not available (one or both of your original
keys were lost or stolen), you must bring your vehicle to your dealership
to have the spare coded key(s) programmed.
Procedure to program spare SecuriLock
Y keys to your vehicle
New coded keys must have the correct mechanical key cut for your
vehicle.
Conventional (non-coded) keys
cannot be programmed to your vehicle.
You will need to have two previously programmed coded keys and the
new unprogrammed SecuriLock
y key readily accessible for timely
implementation of each step in the procedure. Please read and
understand the entire procedure before you begin.
1. Insert the first previously programmed coded key into the ignition and
turn the ignition from OFF to ON (maintain ignition in ON for at least
one second).
2. Turn ignition to OFF and remove the first coded key from the ignition.
3. Within five seconds of turning the ignition to OFF, insert the second
previously programmed coded key into the ignition and turn the ignition
from OFF to ON (maintain ignition in ON for at least one second but no
more than five seconds).
4. Turn the ignition to OFF and remove the second coded key from the
ignition.
5. Within 10 seconds of turning the ignition to OFF, insert the new
unprogrammed key (new key/valet key) into the ignition and turn the
ignition from OFF to ON (maintain ignition in ON for at least one
second). This step will program your new key to a coded key.
6. To program additional new unprogrammed key(s), repeat this
procedure from step 1.
If the programming procedure was successful, the new coded key(s) will
start the vehicle’s engine. The theft indicator (located on the instrument
panel) will light for three seconds and then go out.
If the programming procedure was not successful, the new coded key(s)
will not operate the vehicle’s engine. The theft indicator will flash on and
off. Wait at least one minute and then repeat the procedure from step 1.
If failure repeats, bring your vehicle to your dealership to have the new
spare key(s) programmed.
REMOTE ENTRY SYSTEM
Your vehicle is equipped with a remote entry system which allows you to:
²
unlock the vehicle doors without a key.
²
lock all the vehicle doors without a key.
²
activate the personal alarm.
The remote entry features only operate with the ignition in the OFF
position.
If there is any potential remote keyless entry problem with your vehicle,
ensure
ALL key fobs (remote entry transmitters) are brought to the
dealership, to aid in troubleshooting.
Hope this helps. If you need to look further at the manual (if you don't have the manual for your Expy), you can go to www.fleet.ford.com and go to the Maintenance section, and click on Owner's Manuals. Enter your info and your manual is pulled up.
Old 11-22-2008, 12:11 PM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
If you have remote keyless entry, try using it to lock then unlock the vehicle, then see if it will start.
Old 01-29-2009, 11:31 AM
Brandon_01's Avatar
Brandon_01
Brandon_01 is offline
I am installing the Ford Remote start on my 01 Expy. When I purchased the truck a few months back, I only received one key. Will I really have to have two keys to get this programmed with the one existing key that I have? I really don't want to hand over $75 bucks to purchase a new key and have it programmed by the dealer.
Any help would be great!
Thanks!
Old 01-29-2009, 11:45 AM
Quarterbore's Avatar
Quarterbore
Quarterbore is offline
Can I ask where you got thr remote start? I have been considering an after market add-on for ours as the Expedition is always parked outside.
As for the keys and fobs, my understanding is you do need both factory keys to program additional ones and I am in the same situation as my 2000 only came with one key and one fob.
I am still trying to figure out what other bugs there are with teh truck and if I can fix them or if I need the dealer to address them all at one visit. We have had our 2000 for just under a week.
Old 01-30-2009, 02:14 PM
Brandon_01's Avatar
Brandon_01
I purchased the remote start off of eBay. I went with the Ford one just to stay with the name. It wasn't any more expensive.
Old 05-06-2009, 12:55 PM
birchy's Avatar
birchy
birchy is offline
I'm assuming you figured this out by now tallguy?
I have a related question... With the SecuriLock Anti-Theft system.. can thieves still hot-wire the vehicle if they know what they're doing?
The reason I ask is because I'm contemplating getting rid of our comprehensive insurance to save some bucks.. but I am a bit nervous about theft because I live in a rather large city and we did have our last vehicle stolen in January 2008.
Old 05-07-2009, 05:29 PM
K-Mac Attack's Avatar
K-Mac Attack
K-Mac Attack is offline
Nothing is perfect and I am sure someone can figure out how to steal one of these. Also keep in mind that comprehensive is also good for things like weather damage, vandalism and glass breakage. You may save a few dollars but I don't think it is worth the risk. Don't be penny smart and dollar dumb!!!!
Rustyiron55
1983 - 2012 Ranger & B-Series
06-28-2015 06:11 AM
Lost Yankee
01-20-2014 07:15 AM
stockhelder
6.7L Power Stroke Diesel
25
03-26-2011 07:31 PM
FLsoxfan
Electrical Systems/Wiring
05-09-2004 12:35 PM
CobraXP
09-23-2002 01:13 PM
Quick Reply: Anti Theft system question
