226 carb linkage
226 carbs
Here you go. Note that the car and truck carburetors are slightly different from one another, even though they are both Holley model 847-FS carbs. The choke lever on the truck carb has a ball and socket connection, but the car carb has a screw clamp connection. The one on the right came off of my truck, so some previous owner must have changed out the choke cable connection in the past as well.
The air horns are also different. The truck air horn has a ridged flange at the top and the car air horn does not.
Anyhow, I got all of this info from the Holley 847 repair manual I found at the old car manual project (Holley 847 Downdraft Service Manual / H847-19500001.jpg), so take a look.
Here's some closeups of the truck carburetor linkage:
Hope this helps.
Hope this helps.
BaltoMoJoe
03-23-2015 01:50 PM
mse871859949
12-03-2014 02:09 PM
andrewscofield
05-20-2012 07:10 AM
