Rough idle-'94 F-150 4.9L - Ford Truck Enthusiasts Forums
Old 11-21-2008, 09:25 PM
jesterdog jesterdog is offline
jesterdog is starting off with a positive reputation.
Hi guys. My engine has been idling a little rough lately. Plugs, wires cap, rotor, fuel/air filter are less than a year old. I typically stay on top of the routine stuff. The truck accelerates great. I know the timing is good because I had to set it after replacing the pickup coil in the distributor. I ran some fuel injection cleaner through it, but it didn't seem to make a difference. This has been going on for more than a few tanks of gas. It is the same on both tanks.
I got to looking at the IAC. I need to measure the reistance on it as per the manual. I unplugged it while the engine was running and it did get worse. The idle started doing more of a rythmic surging up then down, then up then down. With it plugged in, it stablizes but is a little rough.
When I say rough, looking at the engine it seems to be perfectly smooth. The engine isn't bouncing. But, I can feel it sitting in the driver's seat.
Ideas anyone?
Old 11-21-2008, 09:46 PM
6CylBill's Avatar
6CylBill 6CylBill is offline
6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.
Quote:
Ideas anyone?
Your seat has Mexican Jumping Beans in the cushion.
Serious note, can you feel it in the steering wheel / breaks / accelerator?
Old 11-22-2008, 08:24 AM
Motorhead351 Motorhead351 is offline
Motorhead351 is gaining momentum as a positive member of FTE.Motorhead351 is gaining momentum as a positive member of FTE.
disconnecting the IAC doesnt prove much, as if the engine was in perfect condition, you disconnect the IAC, it will run worse.
codes? codes that dont trip the CEL?
Old 11-22-2008, 04:37 PM
stractor stractor is offline
stractor is starting off with a positive reputation.
Take a look/change at the gasket between the throttle body and the manifold. There was a bulletin about the gasket being sucked in and causing a vacuum leak. I don't recall the years the bulletin covered.
Old 11-24-2008, 02:06 PM
Yeah, I think I'll remove and clean the throttle body. I sprayed carb cleaner all over the vacuum hoses and the TB but there was no change in idle speed. So, that leads me away from the vacuum leak path. Maybe it's a dirty TB?
thanks for the input. I'll post back after the TB service.
Old 12-02-2008, 09:17 AM
Well, I removed the TB and cleaned it. Looks like the TB gasket might have failed. It is amazing how dirty a TB can get when only air goes through it. Also, the two vacuum lines that connect to the TB were comparable to old marshmellows. I replaced them as well.
Problem is resolved. It idles smooth now.
Thanks for all the help!!!
Tech/mod info links strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 74 01-12-2017 12:46 PM
F250 Triton V10 6.8L IAC Idle Air Control Valve WHERE IS IT? a.beam.reach 1999 to 2016 Super Duty 5 05-06-2012 12:49 AM
1983 F150 4.9L 300 Engine hum/whine mandbprior Ford Inline Six, 200, 250, 4.9L / 300 13 01-25-2012 12:31 AM
1985 ford f150 4.9 carburator that1dude 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 04-20-2011 08:54 PM
1987 F150,4.9 Idles too high pjksr1955 1987 - 1996 F150 & Larger F-Series Trucks 1 10-27-2006 10:51 PM
Tags
1994, 49, 49l, 94, engine, erratic, f150, ford, idle, liter, missfire, rough, running
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
