Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Bio-diesel, Propane and Alternative Diesel Engine Fuels SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-20-2008, 10:23 PM
Rushmore X Rushmore X is offline
Rushmore X is starting off with a positive reputation.
Cream color in WVO
Excuse the long post. Our WVO that we get gets put in a 200 micron filtered 55 gallon plastic barrell that we use as a settling tank before it goes into the reactor. There is a drain as far down in the tank as we could get it, with the outlet to the reactor at about the 15-20 gallon level. the theory was that the water would settle to the bottom, and be drained out leaving less water going into the reactor. After settling out for about a week (take longer when it's cold), the water went to the bottom, however there is also a cream (emulsion?) that formed a layer above the water. Some was in the oil that we got, and some wouldn't go through the filter. Drained about 5 gallons of this out. Is this flour or an emulsion? (It comes from a German Restaurant that uses Canola oil) The question we have is if this stuff goes into the reactor (a GL eco-processor) will it settle in the glycerine, or do we run the risk of it getting in the bio and eventually our engines? Will heating the oil in the settling tank make a difference? thanks.
__________________
2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, AFE stage 1 w/proguard, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, more to follow! Gone BIO!!!
  #2 (permalink)
Old 11-21-2008, 11:42 AM
DeepRoots DeepRoots is offline
DeepRoots is starting off with a positive reputation.
could just be hydrogenated oil... alot of the oil I use does this even in summer. With temperature change more and more becomes the thick creamy stuff.
When I heat mine to 110 or so it all goes dark and liquidy.
Of course I can't see your oil, so don't take this as fact.... I'd pull some and heat it, see what it does, or even pull a gallon og the pure creamy stuff and make a mini batch of bioD and see how it goes.
__________________
'89 Ford F250 7.3 Diesel, used to be c6 I stuffed a zf5 in there now, ATS 088 turbo, 3.55rear, 2wd. Moosepump
  #3 (permalink)
Old 11-21-2008, 11:58 AM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
Creamy stuff in my oil normally indicated water that hadn't seperated out all the way, or sometimes it could be hydrogenated oil. I would heat it up to about 125, turn heater off and let sit 30 min, then see what it looks like, water will still be creamy and hydrogenated oil will turn dark like other oils.
__________________
1997 F250 Crew Cab 4x4
1988 F350 7.3 Crew Cab 4x4 Dually C6
1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual.
(3) 1986 F350 6.9 Diesel
1983 F350 Diesel (3) 1976 F250 390 4x4
  #4 (permalink)
Old 11-26-2008, 04:57 AM
orng1's Avatar
orng1 orng1 is online now
orng1 has a good reputation on FTE. orng1 has a good reputation on FTE.
Quote:
I was going to say water too. Need to boil it out, just heat it a bit and wait for it to clear up. Leave it hot for a good while cover it and let the oil settle. It will clean up the oil and get rid of the water.
__________________
00 F250 5.4L K&N stock box folter, 257k miles.
01 F250 7.3L DP Tuner, Airaid intake, Magnaflow 4" turbo back, 88k miles. Bob
<img src="<a href=http://api.photoshop.com/home_e202e8e80efb4a1696c4980e2d094cf5/adobe-px-assets/c71a8ac8ad5f4072a1981a2a389f6f04 target=_blank>http://api.photoshop.com/home_e202e8...981a2a389f6f04</a>" width="450" height="150"/>
  #5 (permalink)
Old 11-26-2008, 10:00 AM
going to take a liter or so of it and heat it up to see if it clears up.
__________________
  #6 (permalink)
Old 11-28-2008, 01:32 AM
ms1780 ms1780 is offline
ms1780 is starting off with a positive reputation.
you may also try pulling out a small amount and heating it in a frying pan. If it has water it will pop, if it is oil will clear up. Just a thought.
Mike
  #7 (permalink)
Old 11-28-2008, 05:59 PM
Quote:
Mike
yes, will try and get something done in the next few days. Have about 2 barrells now and need to get on it.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
