Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-20-2008, 07:51 PM
Kuskoal Kuskoal is offline
Kuskoal is starting off with a positive reputation.
why double blow an engine?
whats the advantage?
YouTube - 70 Double Blown GTO
why? wouldnt make a really hot air charge? would that put you in turbocharger territory(speaking of a diesel pumping 60 lb of boost, not the 7-10 on mild gas engines)
kinda intrigued me.
  #2 (permalink)
Old 11-20-2008, 09:16 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Freightrain is gaining momentum as a positive member of FTE.
"show"............is the ONLY advantage. Do you notice the very large lag in throttle response? He wings the throttle, then like 4 seconds later it finally revs. That'd take some getting used to.
Might look impressive, but really it's useless. Years back I saw one that had the two blowers hanging off angles from the intake, not one into the other. They both fed the motor separately. Makes for big "WOW" factor.
__________________
*signature delete option*
  #3 (permalink)
Old 11-21-2008, 01:34 AM
2003F-350SuperDty5.4 2003F-350SuperDty5.4 is offline
2003F-350SuperDty5.4 is starting off with a positive reputation.
Definately for show, to increase the boost you can put a different size pulley on. Having stacked one on top of each other is a waste and due to having more to turn = more drag which is a loss in power in theory.
  #4 (permalink)
Old 11-21-2008, 07:56 AM
jarod17's Avatar
jarod17 jarod17 is offline
Nevada CL
jarod17 is gaining momentum as a positive member of FTE.
More money than brains. Twin turbo theory is that using 2 small turbos you reduce lag while still getting the same boost as one large turbo. You can do the same with turbo style superchargers.
All show.
__________________
Jeff-Nevada Chapter Leader
Tell me I can't do it or it can't be done I will go out of my way to prove myself right.
People who say it can not be done, should not interrupt those who are doing it. Tom Monson
1996 F-250 4X4 460, 3.55, e40d
1985 D-350 Eventually going to have a Turbo Cummins
1971 F-250 Eventually going to have a 7.3 turbo Powerstroke out of a '99 or newer F-250
  #5 (permalink)
Old 11-26-2008, 04:37 PM
pfogle's Avatar
pfogle pfogle is offline
Village Idiot
pfogle has a good reputation on FTE. pfogle has a good reputation on FTE.
That's not very effective. The Top sc would be hindered by the lower if not canceled out all together. That's why anyone who does it right puts them on an angle and the the same level. I think the delay was in the crappy video camera he was using, looked like a phone camera.
__________________
1977 F350 Crew Cab, 460, C6 and 4:10 posi.
Life is like a roller coaster, Live for the ups.
Negativity begets hate, hate begets ignorance, ignorance begets stupidity. Don't be stupid.
If you have to ask "Will this hurt?" do not proceed!
Did you like my post or response? Shoot me some love! Click the http://www.ford-trucks.com/user_gall...id=208503&.jpg beside my user name!
  #6 (permalink)
Old 11-29-2008, 06:35 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
Administrator
FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation
Couldn't even maintain a steady idle. More dollars than sense, IMHO. More effective would be a swap of pulleys on a single blower.
__________________
-Ken
If you need to get in touch with me email me at ftsservice at gmail dot com or via AOL IM: motorhavenken. Problems, questions, concerns.... please feel free to contact me.
- "So long and thanks for all the fish."
  #7 (permalink)
Old 12-02-2008, 02:05 PM
Most high power supercharged motors do "lope". Some are much more severe then others. I like the ones where you can almost count the firing order.............
__________________
  #8 (permalink)
Old 12-02-2008, 02:21 PM
FTE Ken's Avatar
Administrator
That's not a lope in the video. Its the idle speed going up, up, up, and down, down down, verses an idle lope (which I love the sound of). This thing sounds very poorly tuned.
__________________
-Ken
  #9 (permalink)
Old 12-02-2008, 07:48 PM
Have to agree, as the hard part with a blown motor is getting the idle mixture just right. With it surging, it's richening, then leaning out, richening, leaning out. With all the rube goldberg going on there I suppose it'd be really hard to get it right. With all that plenum space, it would be hard to get it rich enough to stay constant.
I put a a/f meter on mine(cheapo narrow band), but it still got it just about spot on. Idles cold with no choke, very responsive.
__________________
  #10 (permalink)
Old 12-04-2008, 06:40 PM
FTE Herman's Avatar
FTE Herman FTE Herman is offline
FTE Herman is a splendid one to behold FTE Herman is a splendid one to behold FTE Herman is a splendid one to behold FTE Herman is a splendid one to behold FTE Herman is a splendid one to behold FTE Herman is a splendid one to behold FTE Herman is a splendid one to behold
Man that thing doesn't idle worth a crap.
__________________
2000 Boss Gator 4x4 Kenne Bell
Max HP: Classified
Max Torque: Classified
0-60: Classified
Best 60': Classified
Best 1/4: Classified
Do it right, do it once (perhaps twice if you try to run more than 14psi on stock rods, or if you don't read the instructions properly).
  #11 (permalink)
Old 12-04-2008, 08:24 PM
rsylvstr's Avatar
rsylvstr rsylvstr is online now
Flt Marine Force Corpsman
rsylvstr has a very good reputation on FTE. rsylvstr has a very good reputation on FTE. rsylvstr has a very good reputation on FTE.
not sure, but i asked my wife and got slapped.
THANKS A BUNCH
__________________
Rob - Senior Chief, HMCS(FMF/AW), USNR(now)
2001 SCrew Lariat 4x4 5.4L 4R70W 3.55 's LS
Cooper ATR's, K&N Series 77 CAI
Nasta S/S nerfs, Rancho RSX
http://home.rr.com/robandvic
  #12 (permalink)
Old 12-10-2008, 07:20 AM
Zookie400's Avatar
Zookie400 Zookie400 is offline
Zookie400 is starting off with a positive reputation.
that is the stupidest thing i have ever seen. he is spinning more parts (and spending more money) to accomplish the same thing a single larger blower would do. the setup he has will only boost as much as the top blower will allow. trying to spin both of those faster will end in less efficiency and overall power. he could get a single, larger unit and spin it slower and get more boost or the same boost with more power.
WHAT HAPPENS IF THAT BACKFIRES??? looks like he has about 5 liters of perfectly mixed fuel and air waiting to POP. wanna see 2 blowers fly to the moon?
  #13 (permalink)
Old 12-12-2008, 07:24 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life is gaining momentum as a positive member of FTE.
Quote:
now thats the youtube video i wanna see...
__________________
2003 F250 4x4 CC V10 4" Procomp, all white beauty
"list of previous owned Fords much to long to list here.."
  #14 (permalink)
Old 12-18-2008, 02:05 PM
Blue Bomber's Avatar
Blue Bomber Blue Bomber is offline
Blue Bomber is starting off with a positive reputation.
i like it! i know its just for show, but i would love to see that sticking out the hood of a 1960 falcon!
__________________
1974 Ford F-100, Straight 6, 3 speed on the Tree, 2wd. mostly stock....for now!
(10/6) NEwS flaSh: new clutch, new gear oil in the tranny.
thoughts on fixing daily drivers: work now, sleep later
  #15 (permalink)
Old 12-18-2008, 03:54 PM
FTE Ken's Avatar
Administrator
Sort of like the ricers adding stuff that really doesn't add power, right?
__________________
-Ken
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
