8 lug d44
Ok figures nothing from the 50ttb will swap in but doesnt hurt to check.
It looks like its the high pinion, and does have front disk brakes. It has coil buckets is that something someone else put on or was that stock? Will it be hard to change to leafs?
heres a picture of the front http://www.postimage.org/image.php?v=Pq1em0_S
hmm this is interesting then. Well do you think its worth the effort to swap to leaf spring and swap out my ttb d50 with.
im getting it and a 60 rear for only 350. I want to get rid of the TTB front in my f250 and get rid of my current 3.08 gear ratio. Its just a mud/trail truck only going with 35s or 37s.
That looks like a 78-79 Bronco axle with 8 lug outers bolted up to it. The stub shafts were 19 spline, however (IRC) the inner shafts should have more splines, however I am suffering from a brain fart and cannot quote what the spline count should be.. If you are wanting to swap a 79 and older onto an 80 and newer F250, you are in for a world of hard knock learning. The wedges for the radius arms (78-79) are cast into the housing, which makes that axle a poor choice for a solid axle swap with leafs. Yes its usable, however you have to re-tube that side UNLESS you convert your truck to coil springs.. Earlier versions had the wedges welded in place. IRC, the axle is too narrow to use as is, so plan on re-tubing, or converting to coils.
BIGS003
16
05-21-2013 08:19 AM
mattjensen
04-24-2009 04:28 PM
