T444E governed speed? Can it be reprogrammed?
They are all the same motor, electronics are different. You'd need to get all the wiring from a PSD powered pick-up and run whatever chip you want.
otherwise, if you're stuck using the wiring from the T444E truck, you're limited as to what you can get. If it's a standard trans, that helps a lot, if it's an auto, you're about screwed...
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
I talked with my cousin agin, he's the one that was looking for a med. duty truck w/T444E last spring and I learned a lot about the programming possibilities from him.
He said the Allison auto trans has NO wires going to it, so in the end I don't see why you couldn't just use a Ford PCM if it'll bolt up to the IH harness and run the truck, it should work. Or at the very least, consult with a chip programmer (Tony Wildman or DP Tuner) with the PCM code on the IH motor and see if they can tune for it straight up. These guys are always finding new tuning things, so you never know.
__________________
nibiru
13
01-03-2011 11:49 PM
