Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 11-19-2008, 10:31 PM
BlueOval460 BlueOval460 is offline
Garage is empty, add now
BlueOval460 is starting off with a positive reputation.
T444E governed speed? Can it be reprogrammed?
Hello, My brother is wanting to put a T444E into his 64' F100, I know that the T444E is governed to 2600 rpm- is it possible to have this governed speed modified to that of a PStroke', or can the ecm's be interchanged?
__________________
Resting in Pieces "Brown Mule" 93 F150 SWB 4x4 SDFI 5.0 AOD 3.55's on 31's --full rebuild, .030 over, Crane Powermax 364215 +4 degrees, forged flat tops 9.5:1, slightly worked E7 heads, MSD cap & Rotor, Mallory street strip coil, FRPP 9mm wires, was getting 20mpg highway, 5k in collision damage still runs like a champ
  #2 (permalink)
Old 11-20-2008, 06:22 AM
DZL JIM's Avatar
DZL JIM DZL JIM is offline
PREMIUM SPONSOR
DZL JIM has a very good reputation on FTE.DZL JIM has a very good reputation on FTE.DZL JIM has a very good reputation on FTE.
They are all the same motor, electronics are different. You'd need to get all the wiring from a PSD powered pick-up and run whatever chip you want.
otherwise, if you're stuck using the wiring from the T444E truck, you're limited as to what you can get. If it's a standard trans, that helps a lot, if it's an auto, you're about screwed...
__________________
'96 F-350 Reg Cab 4x4 PSD
'05 F-250 6.0 cc 4x4
DZLJIM.com
  #3 (permalink)
Old 11-20-2008, 10:08 PM
thanks, thats what i was figurin, the trans would probly be an at545 school bus tranny unless i find a good 5 or 6 speed for a decent price, will all of the sensors and connectors hook up to the PS harness or would i have to do a whole lotta slicing and solderin?
__________________
  #4 (permalink)
Old 11-21-2008, 08:03 AM
DZL JIM's Avatar
PREMIUM SPONSOR
I talked with my cousin agin, he's the one that was looking for a med. duty truck w/T444E last spring and I learned a lot about the programming possibilities from him.
He said the Allison auto trans has NO wires going to it, so in the end I don't see why you couldn't just use a Ford PCM if it'll bolt up to the IH harness and run the truck, it should work. Or at the very least, consult with a chip programmer (Tony Wildman or DP Tuner) with the PCM code on the IH motor and see if they can tune for it straight up. These guys are always finding new tuning things, so you never know.
__________________
DZLJIM.com
  #5 (permalink)
Old 11-22-2008, 12:09 PM
thanks man, i knew i had seen the name DzlJim before- from your website, how did that triple turbo set up work out that thing looked like it would be wicked
__________________
Tags
2007, 96, allison, chip, diesel, dt444e, engine, f150, governed, mpg, programmer, reprogrammed, speed, spped, t444e
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
