Won't Shift Into 4 Wheel Drive - Ford Truck Enthusiasts Forums
Old 11-19-2008, 10:06 PM
jimbo123 jimbo123 is offline
jimbo123 is starting off with a positive reputation.
Question Won't Shift Into 4 Wheel Drive
I bought a used 1998 Ford F-150 4X4. I tried to switch it to 4x4 and it would not switch.
Anyone have any idea what it might be?
Thanks
Old 11-20-2008, 08:13 AM
m350 m350 is offline
m350 is gaining momentum as a positive member of FTE.
What type of 4x4,,Shifter on the floor,,,,or **** on the dash ?
Old 11-20-2008, 08:25 AM
IT's the one with a switch on the dash
Old 11-21-2008, 08:02 AM
Do the Dash "4x4" lights come on when you turn the ****?
If they do,,,
There is a vacum operated lever on the front diff,,,some of your favorite penetrating oil sprayed on it may help(may have to remove plastic cover),,check the vacum line for cracks,,or broken,, missing,,etc
also on the fire wall, behind the battery(pass side) there are 2 vacum solenoids for the 4x4 system check them out for cracked vacum lines etc,,
If no dash lights,,check fuses,, any clicks when **** is turned from under dash ?,,I have read about what they call the GEM module,,I have no experience with it,,someone should chime in with a bit more knowledge,,Good luck.
Old 11-22-2008, 09:17 AM
Thanks for all the info i'll slide under the truck to have a look thanks again
Old 11-23-2008, 04:32 AM
HalfTonne HalfTonne is offline
HalfTonne is starting off with a positive reputation.
that there vacuum in your dang ol' 4 wheel drive aint working cause your old lady is usin it to clean the trailer
4X4 stuck on caddy 6.4L Power Stroke Diesel 1 04-05-2014 02:23 PM
4 Wheel Drive Switching ungerp 1999 to 2016 Super Duty 4 02-22-2014 01:11 PM
F250 Instrument Cluster Dash Radio Trim Bezel FORDSDOWNER 1999 - 2003 7.3L Power Stroke Diesel 12 06-09-2013 08:34 PM
4x4 Control Switch DevotedDad 6.7L Power Stroke Diesel 18 07-03-2012 12:46 PM
need help installing transfer case switch navigatorstang 1987 - 1996 F150 & Larger F-Series Trucks 13 01-12-2011 01:12 PM
Tags
150, 1996, 1997, 1998, drive, f150, f350, ford, ranger, shift, shifter, shit, wheel, wont, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
