FOUND THE NAV.150 AND THE WIERD NOISE
I finally found the
150 with the nav. front end!!!
if you want to check it out go to
truckinweb.com and then click on street trucks.
after that you use the search in the upper left
corner,type in 97 fords and your there. this isn't
a blackwood and it is a very cool truck..it's worth checking out.
I also found what was making the rurr rurr on my
98 150,,turned out to be an a/c comp. mounting bolt
was hanging out about 1/16 of an inch. This caused
the comp. to vibrate,but only when the a/c was on
Thanks to all those who helped me out ,,,Miguel
