Cigarette lighter no power, fuse good...
Old 11-19-2008, 02:53 PM
quietman's Avatar
quietman
quietman is offline
I have a 2005 Excursion, and the after replacing a blown fuse for the cigarette lighter, I still do not have power there.
Any ideas?
Thanks.
john
Old 11-19-2008, 04:21 PM
JaySVX's Avatar
JaySVX
JaySVX is offline
Which one? There's 5, and I believe a fuse for each. I know at least they're not all on the same fuse.
Old 11-19-2008, 04:26 PM
ReAX's Avatar
ReAX
ReAX is offline
Have you had the dash a part recently? Is it possible that the plug wasn't reinstalled?
Old 11-19-2008, 05:27 PM
1's Avatar
1 is offline
I agree, make sure theres not another fuse blown for the lighter, theres more then one.
Its possible the wire going to the back of the socket came loose somehow, but with a blown fuse its more likely you burned up a wire/connection somewhere before the fuse was able to save it. Do you know how the fuse was blown? Too much load, or a dead short? If your not sure how it went bad and you dont use it often its possible the wire came off the back and may have grounded out blowing the fuse when you hit a bump while driving. First thing I suggest is trying to get to the back of it and testing for power at teh wires before the plug.
Which one are you not getting power to?
Old 11-20-2008, 09:33 AM
X-70STANG-F150's Avatar
X-70STANG-F150
X-70STANG-F150 is offline
I believe there is a fuse under the dash and one under the hood in the power distribution box
Old 11-20-2008, 12:08 PM
JaySVX's Avatar
JaySVX
JaySVX is offline
Did you blow the fuse again after you replaced it? Did you check it after you replaced it and found it was still bad? Also, there are 4 fuses.
Fuse #2 20A* Power point - floor console
Fuse #3 20A* Power point – 3rd row
Fuse #4 20A* Power point - I/P
Fuse #5 20A* Power point - right rear quarter
Check your fuse panel under the dash for these fuse locations.
Old 11-20-2008, 01:01 PM
quietman's Avatar
quietman
quietman is offline
Thanks for the replys.
I had replaced the #3 fuse, which is for the 3rd row arm rest
power-point thinking it was the Cig. lighter fuse.
The cig fuse(#12) is next to #3. I went by memory on the Cig fuse
location, and was wrong. The fact that the 3rd row fuse was blown
was just a coincidence, and caused me to stop looking.
They were both blown.
My kids no doubt stuck something into the third row outlet sometime
in the past, blowing that fuse.
Now it's all good.
thanks again.
john
Old 03-21-2013, 09:06 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
I cant get my console plug to work, 2000 7.3 ex limited
Anyone got fuse locations and or wiring diagrams?
Poor'it in'her
1999 to 2016 Super Duty
05-05-2014 09:53 AM
Stroker 6.0 fan
09-06-2013 01:23 AM
BigRalph2000
1997-2006 Expedition & Navigator
01-27-2007 07:40 AM
kms910
05-27-2004 02:56 AM
mcb74seabee
Aerostar
06-23-2003 09:11 PM
Quick Reply: Cigarette lighter no power, fuse good...
