1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
OBDII fault PO455 and PO401
Old 11-18-2008, 07:07 PM
2na's Avatar
2na
2na is offline
Gents...
I have 2 faults reading...PO455 and PO401...
Can someone help direct me to what parts I need and
how can I fix it.
It's an older truck, 1999 F250 V10...I really cannot afford
to take it in for service.
Thank you in advance for your help.
Old 11-18-2008, 07:31 PM
06silvercrew's Avatar
06silvercrew
06silvercrew is offline
455 is evap large leak. Coule be gas cap loose, bad seal on gas cap, evap line off or broken. Lots of things.
401 is an egr flow problem. Dont know much about the V10 so im not much help there.
Old 11-19-2008, 01:25 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
The 401 sounds like the DPFE sensor is bad - or a hose is broken going to it - need to check into this more.
The 455 is like 06silvercrew said, something with the gas tank is leaking air into the system - as in, it's open to the atmosphere. Need to check all the hoses, make sure the gas cap is on tight, AND that the filler neck isn't rusted through.
If you want to work more on it, and can do the work yourself, we'll work with you on it
Old 11-20-2008, 12:35 AM
2003F-350SuperDty5.4's Avatar
2003F-350SuperDty5.4 is offline
P0401 = take a vacuum pump, put it on the top of the EGR start the vehicle, pump the gauge, if the idle changes or the truck dies, 99% of the time = DPFE Sensor. Check the two hoses going to the DPFE as they tend to be brittle and break also. Havn't ever seen a EGR issue with those yet.
P0455 can be tought as it could be a loose gas cap (make sure it clicks) maybe a bad cap, have seen the EVAP unit (cant think of the proper name right now) the big black plastic deal by the spare tire that is by the fuel tank (I have seen those broken before) Check the fuel filler hoses. Being it's a large leak you should be able to find something visually, unless you have an EVAP solenoid stuck open.
Warren Hart
09-30-2016 06:35 AM
2oo1 4x4
1997 - 2003 F150
05-15-2014 08:05 PM
grantpage
11-12-2012 09:10 PM
HHjr
1997 - 2003 F150
01-02-2008 02:18 PM
js2326
1997 - 2003 F150
12-31-2003 06:46 PM
Quick Reply: OBDII fault PO455 and PO401
