OBDII fault PO455 and PO401 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-18-2008, 08:07 PM
2na 2na is offline
2na is starting off with a positive reputation.
Gents...
I have 2 faults reading...PO455 and PO401...
Can someone help direct me to what parts I need and
how can I fix it.
It's an older truck, 1999 F250 V10...I really cannot afford
to take it in for service.
Thank you in advance for your help.
Old 11-18-2008, 08:31 PM
06silvercrew's Avatar
06silvercrew 06silvercrew is offline
06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.
455 is evap large leak. Coule be gas cap loose, bad seal on gas cap, evap line off or broken. Lots of things.
401 is an egr flow problem. Dont know much about the V10 so im not much help there.
Old 11-19-2008, 02:25 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
The 401 sounds like the DPFE sensor is bad - or a hose is broken going to it - need to check into this more.
The 455 is like 06silvercrew said, something with the gas tank is leaking air into the system - as in, it's open to the atmosphere. Need to check all the hoses, make sure the gas cap is on tight, AND that the filler neck isn't rusted through.
If you want to work more on it, and can do the work yourself, we'll work with you on it
Old 11-20-2008, 01:35 AM
2003F-350SuperDty5.4 2003F-350SuperDty5.4 is offline
2003F-350SuperDty5.4 is starting off with a positive reputation.
P0401 = take a vacuum pump, put it on the top of the EGR start the vehicle, pump the gauge, if the idle changes or the truck dies, 99% of the time = DPFE Sensor. Check the two hoses going to the DPFE as they tend to be brittle and break also. Havn't ever seen a EGR issue with those yet.
P0455 can be tought as it could be a loose gas cap (make sure it clicks) maybe a bad cap, have seen the EVAP unit (cant think of the proper name right now) the big black plastic deal by the spare tire that is by the fuel tank (I have seen those broken before) Check the fuel filler hoses. Being it's a large leak you should be able to find something visually, unless you have an EVAP solenoid stuck open.
PO401 code and misfires on 3 and 7 2oo1 4x4 1997 - 2003 F150 1 05-15-2014 09:05 PM
po 171, po 174, po 455 toddrochester Explorer, Sport Trac, Mountaineer & Aviator 3 10-30-2011 08:45 AM
lots of codes help itsunday25 1994.5 - 1997 7.3L Power Stroke Diesel 4 07-07-2011 06:22 PM
check engine OBD code PO401 fosterwc Ranger & B-Series 20 08-25-2005 07:33 PM
PO455: Evaporative Emission Control System Leak Lee619 3.8 & 4.2L V6 1 06-09-2004 09:55 AM
Tags
07, 401, 99, econoline, explorer, f250, f350, ford, obd, po401, po455, po457, reading, sport, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
