1979 f150 radio wiring - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 05-03-2014, 01:55 PM
gfburke's Avatar
gfburke gfburke is offline
gfburke is starting off with a positive reputation.
Or maybe since this kraco is analog, this IS the accessory switched power.. because it doesn't need memory.. so that would mean just run a constant 12v and be done? use this black/white for my accessory switched power ?ya?
  #32
Old 05-03-2014, 01:59 PM
gfburke's Avatar
ha, i'm still having my coffee.
ok, that's what I'm thinking. this one power wire is all this old thing needed to run and kick on with the ignition. but the new deck will want a constant 12v for memory.
  #33
Old 05-03-2014, 02:01 PM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
Gotcha, glad that helped. I'm headed for my second cup soon.
  #34
Old 05-03-2014, 02:04 PM
gfburke's Avatar
thanks man. I'll give her a go.
* ey. just txt'd the dude that had the truck. that one wire is ignition power. not constant. damn old krap0..
  #35
Old 05-03-2014, 10:04 PM
gfburke's Avatar
New speaker wire, infinities, cleaned inside the doors, laid out peal & seal all across doors which btw.. wow. even engein sound better. deck is wired up and working.. the the exception of this kenwood not remembering anything after key is turned off.. grr.. it was used. I even ran a fresh power wire from the battery straight to the deck. into it's labeled 'constant'. I'll grab another faceless KDC-108 and swap. left the door panels alone.. i fought the urge. it's fine, this is WAY better than all that trash setup was.
The loose outside door handle didn't bother me before, but now it does. How do you tighten or replace those rivets on the door handle?
Since the dash bezel was off, I washed that, primer and hit it with all mat black.
  #36
Old 05-04-2014, 10:02 PM
gfburke's Avatar
nm. I just switched the two wires. I wasn't "wrong".. the labeling was! weird..
anyways. done.
  #37
Old 05-15-2014, 09:54 PM
fords4life77 fords4life77 is offline
fords4life77 is starting off with a positive reputation.
questions about stock wiring harness?
I am trying to do the same thing. Im hooking up a pioneer deh-1300MP and just want to make sure I am looking at the correct wires. I found a plug that has a yellow/black wire and a blue/red wire. I am looking in the Chilton Ford Pickup and Bronco 1976-86 service manual book and the plug I found looks like it could be the plug for the stock radio. Are these wires correct?
  #38
Old 05-15-2014, 10:54 PM
fmc400's Avatar
MSEE
Yes, that's correct. YELLOW with BLACK stripe is hot-in-accessory power; BLUE with RED stripe is dial illumination.
  #39
Old 03-04-2016, 07:55 PM
Lilhalfy Lilhalfy is offline
Lilhalfy is starting off with a positive reputation.
OK so I have an aftermarket radio in my truck. It turns on and everything, but I don't know how to connect a speaker. Where would the wires connect to make the speaker work?
  #40
Old 03-05-2016, 01:56 AM
gfburke's Avatar
What radio you got? Should be a model # on it. With that, we could look at the back.
Generally, there is a large plug spot, with many connections on it. That is where you're harness would go. Then you have lots of wires off of that. Speakers are usually grey. Ones for left or right, etc. But should know the model #.
  #41
Old 03-07-2016, 07:03 PM
Its JVC. I can check the model number soon
  #42
Old 03-08-2016, 09:34 AM
gfburke's Avatar
ya get a pic of the back.
  #43
Old 03-09-2016, 05:58 PM
This is it.
  #44
Old 03-10-2016, 10:08 AM
gfburke's Avatar
Here is your wiring.
JVC KD-LH3100 Instruction Manual (Page 65 of 66)
4 speakers.
  #45
Old 03-10-2016, 10:21 AM
4 speakers.
Thank you. I'll go check out the wiring right now
radio wiring cmckale 1999 to 2016 Super Duty 4 12-10-2016 08:07 PM
2005 Ford F-350 radio wiring jasonlee232 1999 to 2016 Super Duty 22 01-18-2016 08:54 AM
How is stock radio grounded? Mdc9966 1973 - 1979 F-100 & Larger F-Series Trucks 8 12-08-2015 07:23 PM
1979 F150 am radio ...Looking for Am / FM Radio conversion GOLFER1ESS 1973 - 1979 F-100 & Larger F-Series Trucks 20 01-06-2014 08:41 AM
Radio Wiring Vaokie1 1973 - 1979 F-100 & Larger F-Series Trucks 9 08-23-2010 06:58 PM
Tags
1979, 79, cd, diagram, f150, ford, harness, hook, player, radio, set, speaker, stereo, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
