2004 diesel water seperator - VA
changed the fuel filter & water seperator filter out on my 6.0 liter trying to save money & the dummy light will not go out The drain valve on seperator is stripped & I was unable to drain prior to removing the seperation filter would that keep it from resetting?
Wlecome to the site Brett!
I'll bet the folks in here can help you out: https://www.ford-trucks.com/forums/forum107/ There are several good diesel boards on the site that can help you with almost any issue you may encounter. Check them out and drop in your state chapter when you get a chance: https://www.ford-trucks.com/forums/forum147/
