Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids and Mileage
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Alternative Fuels, Hybrids and Mileage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-18-2008, 09:02 AM
89ford73's Avatar
89ford73 89ford73 is offline
89ford73 is starting off with a positive reputation.
15-w40 for fuel?
i know where an endless supply of free 15w-40 engine oil is. question is can i burn it for fuel? should i heat it up before it goes into the motor? start on diesel, run on oil? mix it 50/50 and go. forget it and just change oil really often?
__________________
94 ford 4x4 with a 5.9 12v cummins propane inject, de-fuel plate and governor springs thrown in the trash can. 3.55 rears 12.5-35 bfg mudders. top speed "faster than you wanna drive it"
89 f-150 recently swapped in 95' 12v 5.9 cummins-np4500 5 speed, 2.73 rear top speed 111 at 3,000 rpms. 97 f250 powerstroke automatic 2wd new daily driver. for sale 89-97 ford 3/4 ton rear ends parts or whole 3.55 or 4.10 ratios. my 97 ford psd
  #2 (permalink)
Old 11-18-2008, 12:54 PM
greenego greenego is online now
greenego is starting off with a positive reputation.
Just change oil really often.
  #3 (permalink)
Old 11-20-2008, 11:50 PM
starmilt starmilt is offline
starmilt is gaining momentum as a positive member of FTE. starmilt is gaining momentum as a positive member of FTE.
worth it to heat your shop with it.
  #4 (permalink)
Old 11-21-2008, 08:36 AM
89ford73's Avatar
i heat my shop with used motor oil. lol, got plenty of that on hand. cant get rid of it all winter
__________________
  #5 (permalink)
Old 11-25-2008, 09:00 PM
jhess jhess is offline
jhess is starting off with a positive reputation.
Waste motor oil
Yes you can use it as fuel. Start at a lower mix about 20% move up slow with each tank and see how much your truck likes. I was burning 80% with no problems on 6.4 2008. I also had to do the SCT DP delete so as not to clog it. Now when outside air temps. are getting colder I have to mix 50%. I have been doing it for 20K miles.
Now as for lubercation add 2 stoke oil. I use 2 cups for 10gal and acidtone to help with the burn.
  #6 (permalink)
Old 11-26-2008, 08:31 AM
89ford73's Avatar
how much acitone per 10 gal? and if you get too much does it become a problem with cold temps. it never gets below freezing here so im probly okay
__________________
  #7 (permalink)
Old 11-26-2008, 08:38 AM
89ford73's Avatar
how much acitone per 10 gal? and if you get too much does it become a problem with cold temps. it never gets below freezing here so im probly okay and would there be any difference between using new motor oil and used motor oil. because i can get all the fresh motor oil i want.
__________________
  #8 (permalink)
Old 11-26-2008, 07:10 PM
waste motor oil
It has beed said that 1 to 3 OZ for 10 gals is good but no more. If you put too much in your tank than your MPG will start to fall off. Also I forgot to say that filtering is important, I filter to 5 microns and you can get new oil that will help going though the filter faster. I mix mine up in a 30 gal drum than add the diesel, 2 stroke oil and acidtone. From there it gets pump to the truck.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
