Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 12-10-2008, 05:26 PM
haldavis haldavis is offline
haldavis is starting off with a positive reputation.
I pretty well ruled out the coil by switching the coil end of the spark plug wires from cyl 3 to 4 and vice versa. Since it fires both of those cylinders at once, I would have expected to see my misfire code move from 3 to 4. It did not. It stayed on 3. Putting a vacuum pump on the EGR valve at idle had little effect on the way the engine ran, so I was pretty sure it was the EGR ports.
Fast forward to last Sunday. I pulled the upper manifold and found the EGR ports half plugged on 1, 2, 4, & 5. 6 was totally plugged. 3 was almost completely open. I cleaned them out with a piece of wire and compressed air. I buttoned it back up and haven't stored a code since. I feel much better about it now.
Thanks for all your help, guys.
  #17 (permalink)
Old 12-11-2008, 11:57 AM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE.
What is it they say????
You 'da man ???
Good news and thanks for sharing. Very glad you got your problem resolved.
Have you any ideas about why the problem might occur? I put 175,000 miles on my 2000 and have (I think) 158,000 on my '05 and I have never seen any signs of problems brewing in the area you just addressed.
I wish I had an idea about why this a problem on some engines, but not others.
Thanks again for posting your fix.
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
  #18 (permalink)
Old 12-11-2008, 07:33 PM
Sorry, but no I don't know why it happened.
There was very little hard crusty carbon. I suppose what was clogging the ports was hard, but just outside the port and throughout the entire manifold and plenum was this sticky gooey tarlike substance. Reminded me of varnish in an old carburetor. That kinda baffles me because there should be no fuel up in that area, and all the air flow should be downward. I have no idea how all that crap gets up into the plenum. PCV valve maybe? It doesn't use oil, though. Anyway, I wonder if the tar/varnish stuff gives the carbon something to start sticking to and it just builds after that?
Tags
1997 , 2001 , catalytic , code , codes , converter , egr , error , f150 , ford , forums , intermittent , p0303 , poking , pressure , sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
