7.3 idi valve cover gasket replacement - Ford Truck Enthusiasts Forums
Old 11-17-2008, 10:42 AM
tpolley tpolley is offline
tpolley is starting off with a positive reputation.
two questions, i've got oil dripping off my oil filter. no, it's not the filter, i just replaced it with no change. it looks like its comming from above the filter. possibly valve cover gasket? it only leaks when the engine is hot. it seems to stop after the engine cools. is there any other place it could come from in that area?
second,
autozone's "do it yourself" section says to replace the valve cover gaskets to free the motor from the motor mount on the right side and rest it on wood blocks between the engine and the frame?? huh?? it doesn't say why. it seems redundant. if i put a block of wood between the engine and frame the engine will be sitting in the same place as if the motor mount was still attached??
does anyone have a better step by step procedure for replacing the valve cover gaskets? is it something a novice could do in the appartment parking lot on a saturday afternoon?
Old 11-17-2008, 10:51 AM
farmert farmert is offline
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
I would check the oil cooler for leaks. It is the long tube that runs from the oil filter base and goes to the front of the motor. The orings get hard and allows oil to leak when the oil gets hot. You can get new orings to replace them from Ford.
Old 11-17-2008, 11:49 AM
GenLightening's Avatar
GenLightening GenLightening is offline
GenLightening is starting off with a positive reputation.
It could be the valve cover or the head gasket. First, clean everything as good as possible and then drive it for a bit. Then check to see where it looks like it's coming from. Better to fix the right problem then to do one thing and think you messed it up and then redo it with no change.
Old 11-17-2008, 12:31 PM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
Did you install the filter as per Navistar/Ford instructions........
VOM FSeries/Econoline Owners guide 7.3 Liter Diesel
Clean the filter mounting area of the oil cooler, lightly coat the gasket surface with clean engine oil and hand tighten until gasket contacts the base. THEN TIGHTEN ANOTHER....... 1 1/4 to 2 TURNS. Fill the crankcase and check for leaks.
To do the valve covers drivers side is just removal and replacement....... Pax side is a bit trickier. filter has to be removed to get all the bolts and clear the rockers, remove air cleaner to allow the cover to be moved rearward, up and in toward the middle of the engine. Oil dipstick should just be there, but no problem.
Please put up a signature with truck info.......
Old 11-17-2008, 11:15 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
tpolley I think you were looking at the directions for removing the oil cooler.
That is the method you use to remove and replace it, not the rocker covers.
Old 11-18-2008, 11:02 PM
ford trans tech ford trans tech is offline
ford trans tech is starting off with a positive reputation.
the left valve cover gasket will drip on the oil filter
yes you can replace it
it isnt difficult but you will need to clean the mating surfaces
the head gaskets on an IDI cannot leak oil
Old 11-18-2008, 11:27 PM
Dodge/Cummins Dodge/Cummins is offline
Dodge/Cummins is gaining momentum as a positive member of FTE.
These filters need to be TTIIGGHHTT!!!!!!!!!!!!!!!!!!
Old 11-19-2008, 12:56 AM
S.P.'s Avatar
S.P. S.P. is offline
S.P. is starting off with a positive reputation.
...OK...
Can the head gasket leak oil, or can't it .
Second.. how about the drivers side valve cover gasket???
Last.. what about aftermarket / or new valve covers
Old 11-19-2008, 01:24 AM
Quote:
Originally Posted by S.P. View Post
...OK...
Yes.
I thought that's what everyone has been talking about?
No aftermarket covers and I don't know if you can still get new ones from IH.
Old 11-20-2008, 07:02 AM
I was under the impression that various things, too numerous to mention, could lift your head and cause you head gasket to leak oil.
I'M NOT SURE!
Old 11-20-2008, 11:08 PM
there is no pressurized oil in the cylinder heads of an IDI
only coolant and compression
oil can only come from the vally pan or the valve cover gaskets
Old 11-21-2008, 03:48 AM
That's GOOD to know!!!!!!!
Old 11-21-2008, 08:31 PM
There are oil drains in the head that go through the head gasket.
But if you have oil leaking out from the drains, you have bigger problems than oil leaks.
How I Changed Oil Pan Gasket on 78 F150 2 wheel drive 300 Ira Brown 1973 - 1979 F-100 & Larger F-Series Trucks 0 01-24-2015 01:30 AM
What should I do about a 92 4.0 leaking oil so bad? 1998Ranger25L153CID Ranger & B-Series 3 01-06-2015 02:51 AM
Raising the block to replace 460 motor mounts & rear main seal..? Chevy Guy Gone FORD 1987 - 1996 F150 & Larger F-Series Trucks 5 10-30-2013 09:47 PM
351M valve cover leaks dnelmo 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 7 07-16-2004 10:42 AM
94 5.0L Oil Pan Gasket Replacement Cardinal 1987 - 1996 F150 & Larger F-Series Trucks 4 02-27-2003 02:10 PM
Tags
1997, 73, cooler, cover, covers, diesel, gasket, idi, leak, leaking, oil, problems, remove, tube, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
