Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-16-2008, 06:23 PM
Fabman54 Fabman54 is offline
Fabman54 is starting off with a positive reputation.
Frame Specs
Hi,New Old Guy Here!
I have 47 Pickup. I need the Frame Specs.(Dimensions)
My frame is in two pieces.
I Need Help Please!!
Thanks
  #2 (permalink)
Old 11-17-2008, 06:46 PM
loholland loholland is offline
loholland is starting off with a positive reputation.
Fabman54, could you give a little more detail on the measurements you require? Length, width, or all the above. My 46 frame is still exposed so I could go out and tape measure any place you want. Also welcome to the forum. I'm an old guy too.
  #3 (permalink)
Old 11-17-2008, 11:24 PM
Frame Dimensions
Thanks for the the responce.
That would good of you to do that.What I like to find is something like this.
http://i300.photobucket.com/albums/n...4/LastScan.jpg
  #4 (permalink)
Old 11-18-2008, 02:41 PM
A detailed drawing like the one for the 40-41 frame you linked in your response is not to be found that I know of (believe me I have looked for a long time) however here is one I found with out dimensions.
http://www.vanpeltsales.com/FH_web/F...942-46comm.jpg . I measured my frame and the width in the rear is 34" outside and 32" in the front. The frame goes in 1" on each side in front of the cab mounting tab.
  #5 (permalink)
Old 11-18-2008, 04:11 PM
Frame Dimensions
loholland
Thanks for the dimensions My frame rails have so many holes, I want to weld them up.I really don't want to have to re-drill any holes. Would it be possible for you to take some pictures,then e-mail then to me?
Thanks
  #6 (permalink)
Old 11-18-2008, 08:04 PM
AJ46 AJ46 is offline
AJ46 is starting off with a positive reputation.
Hi their fellow 40's fan what, measurement where you looking for. I have a 46 1/2 ton model. I might be able to help my old girl is still all stock.
  #7 (permalink)
Old 11-18-2008, 10:35 PM
fabman54, I would be glad to except I don't have a digital camera, however my daughter has one but I won't see her until Thanksgiving if you can wait. Maybe AJ46 can help. My frame has already been modified with an MII IFS and new rear springs with 9". Are you talking about rust through holes? If so, you might want to consider finding another frame. There are some out there for sale for not too much $. Rust through is pretty common under and behind the rear shock brackets.
  #8 (permalink)
Old 11-19-2008, 12:04 PM
Frame Dimensions
loholland,
that will be just fine. Too many drill holes frome previous owners. I want my Frame void of any unnecessary holes.
I too will be using A mustang II in front. Although I I haven't decided
how I will suspend the 9" out back.
AJ46
How's it going? I need as many Dimensions as I can get. My Frame is
in two pices. I also will be boxing in the Frame.
Thanks
  #9 (permalink)
Old 11-19-2008, 10:20 PM
Rehello
Yes I 'll try this weekend to take a few measurments for you ,off my frame ,But it won't be t'll this weekend ,because it gets dark here before I get home. Talk at you soon Roy.
  #10 (permalink)
Old 11-20-2008, 08:55 PM
soule46 soule46 is offline
soule46 is starting off with a positive reputation.
Too bad you are local to me, I have my truck off and am sandblasting right now. I did some measuring and got a few picts. My sandblasting tent is fairly small so the picts are not the best -- its a start though. Let me know if you want more specifics. I cannot verify all of the frame holes, my frame was modified during its history also.
Frame Diagram
46 Ford 1/2 Ton Frame
  #11 (permalink)
Old 11-20-2008, 09:03 PM
Sorry, the picts of the frame are upside down, I blasted the top side already. I did plug the passenger side master cylinder hole, the PO had cut it open more with a torch so I cleaned it up and filled it in for now. The rear most running board bracket is missing on both sides and the forward, rear spring hanger is off (again PO thing and long story).Ask away, I will see if I can get you answers.
  #12 (permalink)
Old 11-20-2008, 10:38 PM
Frame Dimensions
Soule46
Thanks for the pictures and drawing. They will be a grate help.
  #13 (permalink)
Old 11-21-2008, 07:59 PM
That look like a good start to a frame job. Also I found some good frame pics on the net with part break down. Its a ford site, Its under ( The Ford Flathead V8 Site) Also has good pics and part break downs of other components and electrical diagrams.
  #14 (permalink)
Old 11-23-2008, 04:43 PM
Frame Specs
AJ46
I've had it awhile & just started to tinker on it. The holes are Just now
getting welded up. Just a little time consuming.
  #15 (permalink)
Old 11-24-2008, 12:23 PM
Chaosracing Chaosracing is offline
Chaosracing is gaining momentum as a positive member of FTE.
I dont know if anyone ran into this, but I was told by someone that I should get a modern frame for my 47 1 ton if I am going to put a 351M/400 into it. Now I plan on putting a MII front end on it a 9" out back and then box the frame also. I would think that with it being 1 ton and boxing the frame that is should be plenty strong.
__________________
2002 Ford F250 4x4 V10<-FORD's best kept secret.
1947 Ford 1 Ton
2001 Sport Trac (Wife's vehicle)
Powered by Ford, Fueled by Madness
Support America and capitalism....BUY A FORD!!!!
Tags
1947 , dimensions , ford , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
