Go Back   Ford Truck Enthusiasts Forums > Misc. > Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.SPONSORED BY:
Click Here
  #1 (permalink)
Old 11-16-2008, 05:22 PM
jcascio's Avatar
jcascio jcascio is offline
Garage is empty, add now
jcascio is starting off with a positive reputation.
Maaco bed liners and paint job? Tonneau Cover?
I have a 66 F-100 that needs a paint job. I'm thinking of having it done at Maaco; and also having them do a pour in bed liner. After that I'm planning to put a tonneau cover on it. Does anyone have any experience - good or bad - with Maaco, bedliners, and Tonneau covers???
  #2 (permalink)
Old 11-16-2008, 09:05 PM
Customcab's Avatar
Customcab Customcab is online now
Customcab has a good reputation on FTE.Customcab has a good reputation on FTE.
Maaco, is great if your budget doesn't allow for a more detail job; I recommend stripping it down (remove bumpers etc) to allow a better coverage. They add acouple bucks to shoot inner stuff like door edge & hood area. I didn't know they had a bed liner capability. I had mine sprayed with a Speedliner product (65 in my gallery). If your bed is solid and no major flaws I recommend just painting it with paint, once a bed liner is roll or spray there's no easy turning back.
Bed cover is cheaper & looks just as good as with or without it cover in my opinion.
Mitch
__________________
Mitch
63 F100 LWB 302/AOD (Orphan box) Daily Driver.
62 F100 LWB 292/3spd (Uni-body Big Window)
57 F100 SWB 351C/FMX; (Big Window)
93 F150 4x4 Regular Cab Daughters 2nd truck
62 Flairside SWB "Wife truck"
  #3 (permalink)
Old 11-17-2008, 06:20 AM
ddavidv's Avatar
ddavidv ddavidv is offline
ddavidv is starting off with a positive reputation.
Maaco can do decent paint jobs, but they seem to be inconsistent. I've seen paint applied too thin, and I've seen really nice jobs. However, the bodywork is what it's all about. If you don't have good bodywork no matter how good the painter it will look like crap.
Maaco single stage paint in a factory color (not the el cheapo, lowest cost job they sell which is awful) runs at least $600. If you want clearcoat, double that.
If this is for a 'working' truck that just needs to be all one color and looks good from 5 feet away, there is another alternative. You can paint it yourself for around $200 all inclusive, without a spray gun or compressed air source. More labor intensive (lots of sanding) but you get to tell people you did it yourself and they won't believe you. A 1962 Ford Falcon Recieve A Budget Paint Job - Hot Rod Magazine
Home
Rickwrench, Alfa GTV, Falcon Squire, Corvair
Check out the links within these links for even more info.
Yes, it's for real. I've done it myself.
One caution on the bedliner: make sure you remove the bed mounting bolts before it gets applied. Trying to remove the bed bolts after the stuff hardens is near impossible should you ever need to pull the bed.
__________________
'65 LB Custom Cab 352 3 spd.
  #4 (permalink)
Old 11-17-2008, 12:19 PM
jcascio's Avatar
Thanks. Tonneua cover?
Thanks so much. Really appreciate the advice! What about a cover? The people I talked to at Tonneau say they don't make a cover for the '66.
  #5 (permalink)
Old 11-18-2008, 07:13 PM
Customcab's Avatar
Good question; I've seen a few with after market covers. Never ask where they bought it or if modification where needed.
I plan on covering my 64 swb with marine grade vinyl. My bed floor is shot, I've done several using this type cover, I use 1" L shape angle iron on the inner side rail, then use pressure treated plywood as base with 1/2" foam then cover with vinyl. The tailgate sort-of-locks the cover into the bed rails. Cheap and easy to do.
Just to give you some though....
Mitch
__________________
Mitch
  #6 (permalink)
Old 11-19-2008, 06:13 AM
Hakk Hakk is offline
1965 Ford F-250
Hakk is new and has a neutral reputation at this point.
My understanding is that Truxedo (one of the sponsors of this web site) will do a tonneau cover to fit the early Fords. I don't know how much, though.
I've done the Rustoleum and rollers paint job and it's cheap but a lot of work. I had some trouble buffing out the paint, but I ended up with something that was good enough (I was happy with it) for less than $200 including the tools I bought.
__________________
'65 Ford 250 custom cab camper special
'99 F-250 SD V10
'70 Mustang convertible carbed '89 roller cam 302
Tags
bed, bolts, cover, custom, f250, forum, highboy, inline, job, jobs, liner, liners, paint, paintjob, tonneau
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
