Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-16-2008, 05:26 PM
Highway 101 Highway 101 is offline
Highway 101 is starting off with a positive reputation.
Help..Replacing a 1959 292 with a 1954 239
Hi,
I am new to Y-blocks and new to this forum. I have some engine swap questions that I hope some of you can help me with. I recently picked up a rebuilt late 1954 239 pickup engine that I am hoping to replace the seized up 292 engine in my 1959 Edsel (hope it's okay to ask about a car on a truck forum). I thought this would be an easy swap, but it is getting more complicated and I don't have enough info to know what will work.
First of all, I need to change oil pans, pickup tube and dipstick location. This looks pretty straight forward.
I don't know what to do about the intake and carb setup. The 239 has the early style 3 bolt carburetor (linkeage on wrong side), and the manifold has no provision for my transmission kickdown linkeage. Can I install the 1959 2 barrel intake on the 1954 239 or will the size of the intake ports cause me significant problems? Another option is to buy an adaptor to fit my 1959 carb on the early manifold, but that doesn't solve my trans kickdown problem.
What do I do about distributors? Can I just leave the 239 distributor alone, or is it 6-volt.....is that even a problem?
It looks like I need to change water pumps because the 1954 water pump has no provision for bolting on a fan. Straight forward???
It also looks like I need to use the 1959 fuel pump because it has vacuum lines that go to the wipers. Straight forward???
These are the problems I have come up with so far. Any advice is much appreciated. The reason I am putting this older 239 in my car is because this one was rebuilt and given to me for free, and I thought it would be an easy swap.
Thanks for the help,
Highway 101
1959 Edsel Ranger
1966 F350 (company truck)
1981 F100 step side
  #2 (permalink)
Old 11-17-2008, 10:52 AM
pintoplumber pintoplumber is offline
pintoplumber is starting off with a positive reputation.
The 239 fuel pump only fits the 239.
Intake mismatch on port size will probably be a problem, mine worked a year and a half before it leaked.
Does the 59 edsel use a front motor mount?
239 water pump is a different size than later engines, not sure of shaft size.
The distributor will run on 6 or 12 volts,but it is vacuum only advance comming from the 3 bolt carb. distributor won't work right with another carb.
Dennis
  #3 (permalink)
Old 11-17-2008, 01:05 PM
Dennis,
Thanks for the info. Wow, this is getting more complicated. The 59 Edsel does not use a front motor mount and it looks like the 239 has the threaded holes in the side of the block that I will need. The water pump is a bummer. How did they hook up a fan on the 239? there are no bolt holes on the water pump pully for that. If I go with the 59 carb, can I run my 59 distributor or will it not engage in the oil pump correctly (or however that works)?
Thanks,
Highway 101
  #4 (permalink)
Old 11-17-2008, 03:39 PM
The 59 distributor has a 14 tooth gear, hex drive. The 54 239 has a 13 tooth gear tang drive.
I've converted mine to the later distributor for better performance. You have to pull the 13 tooth gear off and put it on in place of the 14 tooth gear. Can be a tough job. You'll need the hex drive, and will need to change the oil pump.
For some reason, I had to shorten the hex drive about 5/16" so the distributor would sit flush with the top of the block.
I have a 54 car engine, my fan is on the end of the water pump shaft.Perhaps you could get a 54 car water pump and mount the fan to it. Maybe you could move the whole timing case cover to the 239. Dennis
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
