1979 vacuum diagram - Ford Truck Enthusiasts Forums
1979 vacuum diagram
Old 11-16-2008, 12:56 AM
b54a5d4 b54a5d4 is offline
b54a5d4 is starting off with a positive reputation.
1979 vacuum diagram
Hi all, been lurking for a while and gleaned a lot of great information but finally realized I better ask for some help. I know this subject has been talked to death but I need a vacuum diagram that shows how my truck should be setup. I've looked at mil1ion's docs, read the many posts related to this and looked through most of the stuff Autozone has but still don't see anything that looks like what is currently on it. Here is the info I have:
Calibration sticker is still on the engine but difficult to read. I'm pretty sure the relevant areas say "61G" and "0" If I understand correctly that should make my calibration code 9-61G-R0, right? I found a diagram at Autozone for 9-61G-R0A but it looks nothing like what I have.
Other, possibly relevant info is as follows: 1979 F250 Custom 4x4, 400, manual trans, no A/C, Fed emissions (MN) and has a Cat.
Some history that may make a difference too is that this is its second engine. The same dealer where the truck was originally ordered from installed a Ford factory rebuilt 400 around the late 80s/early 90s. I messed this up pretty bad myself by disconnecting things and not having the forethought to mark down where it all was supposed to go. Any help is greatly appreciated!
1984 E150 emission controls craig47 1968-2013 Full Size Vans 0 04-09-2012 09:13 PM
Engine selection, CR and Gas Octane? 66_in_ky FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 08-22-2007 10:16 PM
Choosing the right Vacuum Diagram? honkytonk 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 01-14-2007 01:34 AM
79 F150 vacuum diagram or Calibration No. jsandlin 1973 - 1979 F-100 & Larger F-Series Trucks 7 11-09-2006 04:58 PM
vacuum diagram hyperhog 1978 - 1996 Big Bronco 3 07-23-1999 09:18 PM
Tags
1979, 351, 351c, 400m, 66, diagram, f100, f150, f250, ford, schematic, simple, vaccum, vacum, vacume, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
