4.6 romeo timing chain alignment - Ford Truck Enthusiasts Forums
Old 11-15-2008, 04:42 PM
Jim88554 Jim88554 is offline
Jim88554 is starting off with a positive reputation.
Exclamation 4.6 romeo timing chain alignment
doing valve job on '97 F-150 4wd, Haynes manual is confusing.
According to manual:
Removal:
"When positioning the engine at TDC for number 1 piston, look at the keyways on the camshaft sprockets. Use a square to insure that each keyway is at 90-degrees to the valve-cover mounting surface of the cylinder head. then install the camshaft positioning tool on the rear of the camshafts."
Installation:
"The two timing chains should each have two bright or colored links.The links seperate the chain into two equal halves. If no colored links are present, lay the chain down, make a paint mark on a link, then count links and make another paint mark halfway around the chain"
"Install the left timing chain, aligning its colored link to the mark on the crankshaft sprocket and to the timing mark on the camshaft sprocket.
Install the right timing chain, and its crankshaft sprocket. When both chains are installed and all colored links and marks aligned, the keyways should be at 90-degree angle to the valve-cover mounting surface of the cylinder head."
Actual:
Removal:
Did not use the camshaft positioning tool but did insure that keyways were at 90-degrees to the valve-cover mounting surface of the cylinder head. After I took the tensioners off the chain was still under tension due to valve spring pressure, and when I took the chain off, the camshafts rotated slightly.
Assembly:
Put camshaft at near 90-degrees when heads were reassembled.
Put chain mark on crankshaft sprocket mark and placed sprocket on crankshaft. Crankshaft sprocket mark at 6:00.
Put camshaft sprocket on but when keyway is at 90-degrees the dimple in sprocket will not line up with mark on chain.
The dimple is at about 4:00 (keyway at 12:00) mark lines up with keyway but no tension is on chain. I can rotate the camshaft a tooth or two to put chain back under slight tension (so keyway is at 90-degree angle to the valve-cover mounting surface of the cylinder head) but marks do not line up.
How should I proceed? any and all help will be greatly appreciated.
Old 11-17-2008, 08:09 PM
Gevans17 Gevans17 is offline
Gevans17 is gaining momentum as a positive member of FTE.
timing info
I might be able to help if you enable your private messages
Old 11-17-2008, 09:13 PM
tsedgar tsedgar is offline
tsedgar is starting off with a positive reputation.
Don't you need 25 post before you get this option?
Old 11-18-2008, 05:54 AM
dont know how to enable private messages
Old 11-18-2008, 07:21 PM
Quote:
didnt know that!
Old 11-19-2008, 08:15 AM
Continued with assembly, placing keyways at 90-degress to valve cover mounting surface and noticed that timing marks on camshaft were 180-degrees out, turned engine over by hand several rotations, and had no interferance. Since the camshaft rotates 180-degrees for every 360-degrees of crankshaft rotation I believe I will have no problems
Need help timing!! MoJensen87 1997-2006 Expedition & Navigator 10 08-06-2014 02:02 PM
2001 Ford F-150 4.6 Romeo Timing Chain Replacement Dark Green F-150 1997 - 2003 F150 0 05-13-2014 03:44 PM
2002 Ford Expedition Timing Chain Problems Hunter_D 1997-2006 Expedition & Navigator 2 10-04-2013 11:42 PM
Timing chain for Expedition molin3 1997-2006 Expedition & Navigator 3 02-22-2009 09:17 PM
4.6 timing chain alignment Jim88554 1997 - 2003 F150 3 11-17-2008 05:39 AM
Tags
180, 46, 46l, alignment, cam, camshaft, chain, f150, ford, positioning, put, romeo, tdc, timing, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
