water seperator left open
Old 11-15-2008, 02:26 PM
resler's Avatar
resler
resler is offline
help i changed my fuel filter today and forgot to close the seperator i made it about 100 yards and the truck died. i opened the hood and closed the seperator. after cranking for awhile it started and ran bad for about 1 minute and now it wont start at all. do i have air in the lines and if so how do i get this fixed
2001 f250 7.3
Old 11-15-2008, 03:33 PM
fire240's Avatar
fire240
fire240 is offline
You probably do have air in the system. I am not familar with the newer 7.3. You might want to ask these guys.
https://www.ford-trucks.com/forums/forum31/
Old 11-15-2008, 06:31 PM
mongo75's Avatar
mongo75
mongo75 is offline
Yeah, you just got air in the lines. I'd turn the key on and off a few times to fill the fuel filter bowl, and then crank it till it starts. It will run like crap for a few minutes till the air is gone though.
NOTE- next time you do that, let me follow you with a bowl to get some free fuel!
Old 11-15-2008, 06:35 PM
zx250's Avatar
zx250
zx250 is offline
Of the next Riffraff East
Yep, like they said, cycle the key for about 20-30 second allowing to fuel pump to purge the systems. Don't crank more than 15-20 seconds at a time to keep from burning up the starter. Make sure you batteries are up to par and don't worry about mowing the grass in the 100 yard stretch.
Old 11-15-2008, 06:51 PM
Whitey Ford's Avatar
Whitey Ford
Whitey Ford is offline
FTE-Spread The Knowledge
After doing a complete service, I forgot to close the WS valve. I was letting it run and went to feed the horses and as I was walking back the truck starting running real rough and I could see fluid flowing out under the front. I knew exactly what I did. I closed it and started it back up. It ran really rough. But I had read in a thread that it will work the air out. It took a while and a few trips but it did work it out. I have NEVER forgot again.
Good Luck.....
Old 11-16-2008, 01:14 PM
resler's Avatar
resler
resler is offline
ok im not sure my problem i changed my fuel filter cause i though it was dirty and left the seperator open. i had some stalling problems before i changed it and thought it was filter. it did it at different times no patterns though. after i changed filter and closed seperator i had it started twice it died both times and i cant get it started now. it bowl is full olf fuel and the tach jumps when i try to start it i just had batteries tested and they are good. it sounds like it is trying to hit but it wont start. any help would be appreciated
Old 11-16-2008, 02:22 PM
zx250's Avatar
zx250
zx250 is offline
Sounds like it is still got some air in the fuel lines. Try cycling the key several times, allowing the pump to push the air out. Make sure you valve is not letting more air in and the cap is on tight, in other words, no fuel leaks. You may want to charge your batteries good. Extended cranking will weaking them and prevent starting.
You may have a CPS problem as well. The stalling and restarting are classic symtons and complete failure will cause no start. The tach usually don't move when bad, but not always.
Old 11-16-2008, 02:40 PM
UP_There's Avatar
UP_There
UP_There is offline
I'm betting on the CPS.......I once had mine go bad when I ran the truck completely out of fuel. Not sure why it toasted it, but it did. It's a good idea to change it out anyways if you have the old style one in. Dealer sells the new "updated" gray ones for like $25 bucks, or DP Tuner sells the better black ones for $65 I think. Some have had issues with the gray, I haven't.
Old 11-16-2008, 05:39 PM
resler's Avatar
resler
resler is offline
ok i got it started after all day of trying. it ran really bad no smoke and it acted nlike it was starving for fuel so i drained the bowl and closed the drain this time. i had my wife turn the key on and i looked in the bowl while it was empty and i saw the bowl fill slowly very slowly and it only filled up about 1/4 of the way. i then went to listen for the fuel pump on the rail and could here it and stop about 20 seconds later. it there any way to test my pump without the fuel gauge. and does this sound normal please help need my truck for work.
Old 11-16-2008, 05:59 PM
zx250's Avatar
zx250
zx250 is offline
Should fill much faster than that. Assuming you have fuel in your tank, you may have the pickup screen in the tank clogged, or the inlet screen in the pump clogged, or a bad pump. Unhook the lines pre pump and using an air hose, blow into the tank, try again. May be a good time to do your intank mods. You can check your pressure with a gauge, but if you are only getting a 1/4 bowl in 20 seconds, you know you have delivery problems.
Old 11-16-2008, 06:15 PM
resler's Avatar
resler
resler is offline
what would the tank mods be and how will this help over the original eguipment? thanks for your help i can feel the stress releasing slowly
Old 11-16-2008, 06:21 PM
resler's Avatar
resler
resler is offline
thanks for your help.. what would the mod be and how is this better than the original equipment. i had tank off about a month ago and the screen on the pickup looked good is the screen on the main pump a finer filter? to look at that one do i have to take the pump off truck and that it or is there more to it
Old 11-16-2008, 06:40 PM
zx250's Avatar
zx250
zx250 is offline
Harpoon mod (In Tank Mod)
Fuel By-Pass And Regulator Install pictures from cars photos on webshots
The links above show the mods I was talking about. It removes the parts of our OEM system that allows air in the system and slower fill ups.
The screen in the pump is just there to prevent large debris from going through the pump. Sometimes it gets trash and prevents good flow. You will need to take the fuel lines off to get to the pump screen. When you were watching your bowl fill, was there air bubbles,or just a slow steady stream of fuel. You may also want to check voltage at the pump. Make sure your getting full power and good ground.
Old 11-16-2008, 06:56 PM
resler's Avatar
resler
resler is offline
no i saw no air bubbles so the pump or clogged lines would be problem then could i take line off in front of pump and turn key on to see fuel coming out of line and if so how far or fast should the pump pump fuel? should it spray fuel a foot out of line or more or less do you think? i looked at the mod photos and the picture didnt look like the pump was pumping very fast in the yellow can? is there a volume that it is supose to pump in a minute like two gallons a minute or someting?
Old 11-16-2008, 07:00 PM
zx250's Avatar
zx250
zx250 is offline
You could, but chances are the clog will be pre pump. Not much place for a clog between the pump and bowl. As far as the steam, a good pump will have around 60psi adn that will wet you pretty fast. You could take the line off before the pump and see if you have a flow there. Should gravity feed at a good stream.
Syriax
6.4L Power Stroke Diesel
11-30-2016 11:29 AM
markturik
10-03-2016 05:20 AM
chi6488
21
10-11-2011 08:09 PM
skono
12-18-2010 12:17 PM
pdarbs
1999 to 2016 Super Duty
10-28-2010 03:05 PM
Quick Reply: water seperator left open
