old spot dont wanna run
ok on my 79 150 4x4 351 with a 4 speed it keeps cuting out at highway speeds runs like a bat outta hell through 3rd but when i get into 4th going down the highway it sputters and jerks like its running out of fuel (so if u slow down and let it idle with cluch in idles perfect and will take off and run again)so i rebuilt the carb checked all the vacum lines and it still doing it ???????? any ideas here guys im stumped.. ps. it has good fuel line pressure
Sounds like you need to check the volume of fuel reaching the carb and if the pumps good must be a restriction in a line somewhere. if you take it easy up thru the gears will it run in 4th for a short time? I just pull the fuel line and run the end into a measurable container, you should have about one ounce of fuel for each pump if I remember closely, someone will correct me if I am wrong I hope. so a dozen pumps would fill a 12 oz bottle or so, could be a weathered fuel line also sucking air too..
