Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-14-2008, 06:55 PM
bossjb bossjb is offline
bossjb is starting off with a positive reputation.
4.2 Oil Pump Install
Hey guys I was wondering if there is a special tool or any specific information needed to replace the external oil pump on my 97 F150 w/ 4.2 auto. Just wondering, didn't want to find out after jumping into it with both feet that I may need something.
thanks, Jeff
  #2 (permalink)
Old 11-14-2008, 10:02 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
I believe you still have to drop the pan to remove the pick-up tube before removing the pump I believe. I could be wrong.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #3 (permalink)
Old 11-15-2008, 02:08 AM
bokker bokker is offline
bokker is starting off with a positive reputation.
hi, its simply bolted on. be carefull when removing it because the oil pump drive is very thin and easy damaged.
i may be off base but why the replacement. i changed my pump due to loss off pressure only to find that the problem was coolant in the oil.
97 was the bad gasket year and distroyed my engine. bokker.
  #4 (permalink)
Old 11-15-2008, 12:50 PM
Because best I can tell it is going bad. When its at normal running temp and I stop (stop sign, red light) and the rpm's drop to idle while in gear the oil pressure bottoms out and the light comes on. I can put it in neutral or park or just increase the rpm's and it jumps back up to normal. I don't think its a bearing issue because the pressure would probablybe low all the time if that was the case. I am going to do a compression test today to see what it reads across the board just to be sure on the head gasket but there is no coolant in the oil.
Jeff
  #5 (permalink)
Old 11-15-2008, 03:55 PM
hi again, the symtoms were exactly the same as yours with the oil pressure dropping like a stone at low revs. keep a close eye on your coolant level, to be sure.
the issue with the gaskets was not head but lower intake and timeing case gaskets.
do a search on the v6 4,2 forum "hydro locking" and hopefully it may save you the cost of a new oil pump. hope all is well bokker.
  #6 (permalink)
Old 11-16-2008, 10:01 PM
Looks like an oil pump fixed it. I let it idle for about 20 minutes after I got finished and then drove it around for about 20 more and haven't noticed any fluctuation in the gauge. I'll give it a couple more days to make sure but it looks promising. Thanks for the help..
Jeff.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
