Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-14-2008, 03:14 PM
53OlderThanMe's Avatar
53OlderThanMe 53OlderThanMe is offline
1953 Ford F100
53OlderThanMe is starting off with a positive reputation.
Oil Pump Drive Shaft Question
The new shaft I purchased has a round tab on one end. Am I correct in assuming this goes toward the driveshaft and is used to prevent you from pulling the drive shaft out when you yank the distributor?
It seems to stop the shaft from coming up thru the distributor hole. This was missing from the 2 engines I've had apart but I remember reading about it somewhere.
__________________
1953 Ford F100, 2000 Expedition, 2008 Silverado (gasp) 1500 Crew Cab
Check out my progress at www.vassh.com
  #2 (permalink)
Old 11-14-2008, 05:26 PM
luckydoggy's Avatar
luckydoggy luckydoggy is offline
Garage is empty, add now
luckydoggy is starting off with a positive reputation.
Yep. Its so the the drive shaft doesnt lift out with the dizzy and then drop off and land in the oil pan. It happened to me once and it sucks
__________________
79 F100 2WD SB. 351w/C6 3.89 9" Autofad 5" lift and some other stuff
  #3 (permalink)
Old 11-14-2008, 07:43 PM
MBDiagMan's Avatar
MBDiagMan MBDiagMan is offline
MBDiagMan is gaining momentum as a positive member of FTE.
Yes and when you put it in you need to adjust that star washer so that with the oil pump in place, the star washer is VERY close to the top. If you leave too much space, the shaft will come far enough out of the oil pump to come loose and fall into the pan.
__________________
Doc
ASE Master (expired)
Cars: 1964 Galaxie 500 Fastback, 2006 Mustang GT Five speed
Trucks: 1978 F150 Shortbed 4X4 that I bought new, 2000 F150 RC, Flareside, 4.6, 5 speed 4X4, Wifes 1998 F150 Blue(very important) 4.6 Flareside
Plane: 1948 Cessna 140
Tags
1953, 302, 351w, 50, drive, driveshaft, f100, ford, loose, oil, oilpump, pump, shaft, v8, wwwford351woildriveshaft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
