You can try leaf clamps first on the back of the
springs to see if that fixes it. It will stiffen up the ride though. An inexpensive option a lot of Lightning guys have used is the traction control spring made by Hellwig. It mounts like a helper string and helps reduce or eliminate spring wrap which causes
wheel hop. Years back Roadmaster had a system which was supposed to help, but I don't know if they are still around.
I'm running a 3 inch drop on the back, 2 inch on the front, with long tube headers, dyno tune, bigger boost pulley, full exhaust with high flow cats, putting out a ton of power with the Roushcharger and I'm not seeing
wheel hop. Sometimes the pinion angle can contribute to this problem, maybe the extra 1" drop is a factor. Or maybe the leafs are crap because
wheel hop is usually a symptom they aren't stiff enough. The Roush leafs on my truck have given me no problems (so far).
FYI... don't know if you know this, but the JDM airbox for the Saleen system is really the Roushcharger air box. Its freaking massive and there is no larger air box for the F150 than the Roush unit.
