Gauges
#32
Reps for voltmeters! I lost an alternator in one of my other trucks last winter in the middle of snow storm. What if I could have seen it go bad before the snow storm? Could be quite handy.
Up with boost, down with HPOP.
egt
trans temp
oil temp
oil pressure
water temp
volts
boost
fuel pressure
The only sensor locations i am having trouble researching are oil pressure and coolant temp locations for the 6.0. Billet caps will cover oil temp and fuel pressure, drill and tap for egt and boost, trans in test port, voltmeter i reckon has numerous locations.
egt
trans temp
oil temp
oil pressure
water temp
volts
boost
fuel pressure
#33
Coolant temp, there is a port/plug in the side of the block:
Install Pictures
Even gives you the part number for the adapter.
If you don't want to do the billet cap for the fuel pressure:
Install Pictures
Not sure on the oil pressure.
Install Pictures
Install Pictures
#36
You can do that and I have thought about it but I don't think it would be very accurate. I believe there is a test port under the oil filter housing that you can use for oil pressure or temp but you will need adapters and fittings there also. I figure one in the billet and one in the test port should be good.
#37
on
If you do both in the test port that would be better then in the billet. Otherwise put one in one spot and one in the other. However, you will need to get a bunge for the one that is going in the test port.
#40
Yep, on the 05-07 they have pods for 4 on the A pillar, 4 overhead above the mirror. And I believe that the 1 gauge pod for the steering wheel column works as well.
So you could have 9 total in autometer pods.
Those all work on 03-04 6.0s as well.
For the 03-04 6.0s there is also the under dash pod, for another 3 gauges.
And the cluster bezel for another 2 gauges.
So on a 03 you could easily mount 14 gauges in the different Autometer pods
#42
#43
#44
on
Let me know b/c for the life of me I couldn't get mine to work and I would like to think I'm not that dumb to not be able to put a gauge pod on there. However, I kinda grown to like the custom job I did for the one that I have on the steering column.
