Cracked Block
Cracked Block
Hello
i am rebuilding my first engine it is a 390 out of a 76 f150
i took it to the machine shop and he told me it was cracked at the rear freeze plug. he said he may be able to fix but wanted another opinion. so my question is if it is worth fixing a cracked block or if you are better of getting a new one. And if you don fix it could there be future problems.
Thanks
Green
Thanks
Green
i did my research when choosing a machinest and i think he is pretty good. i was told that it was a small crack on the exterior of the block next to a frost plug and he would only charge 85 for the fix. i think i will try it. i was wondering if i just make the antifreeze mixture like 75/25 if that would stop the possibility of it freezing and cracking again
75/25 might help in keeping the coolant from freezing, but not necessarily keep it from cracking again. A bare block from the junkyard is less than $50, and if he is boring out your existing block already, it wont cost much more to have another used block cleaned and mag'd. If the block checks out OK, I think you would be ahead a bit, but if it comes up bad, you loose on the gamble. In the factory repair manual ('74) there is a brief section on cracks. The fix, epoxy in the block. The repair is only doable if its in the water jacket, it has an illustration on where the repair is applicable. I am not sure I would have trusted epoxy from 30 years ago.
Not all machinists are worthy of listening to. I have drive 3 hours to get a machinist that is worth two cents that don't do botchery and call it an engine.
airportcop
05-30-2022 03:08 PM
dadstan76
11-14-2015 08:46 PM
ChuckDamage
09-19-2012 10:07 PM
