Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Ohio Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ohio Chapter Join Chapter, Leader: RUNVS
  #1 (permalink)
Old 11-13-2008, 09:33 AM
fastshelby fastshelby is offline
Garage is empty, add now
fastshelby is starting off with a positive reputation.
99 psd need some help!
can anyone help i have a 99 f350 6speed diesel i was driving two days ago the service engine light come on and the truck shut off so i towed it home check all the norm like the fuel bowl was full filter was just done and still clean oil is good i can hear the fuel pump running i put a new cps from the ford dealer in it and the truck started up for about 20 sec and shut off if sits for a while it will start the same and shut down again i have another 99 f350 so i swaped the computers and still nothing but the other one runs either way i also checked all fuses and there good so im stuck any help!!!!
  #2 (permalink)
Old 11-13-2008, 10:59 AM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is offline
bigwin56f100 has a great reputation on FTE.bigwin56f100 has a great reputation on FTE.bigwin56f100 has a great reputation on FTE.bigwin56f100 has a great reputation on FTE.
You might want to replace the I believe its called an ITP sensor? The injectors need 3500 PSI oil pressure to fire. There is an oil rail that holds 3500 psi and if the pressure isnt pressent or the computer isnt sensing pressure it wont run. I'm no expert but we have these at work, but I dont get involved with them much.
Kevin Bigwin
__________________
"Some trucks must die for other trucks to live"......... Kevin
  #3 (permalink)
Old 11-13-2008, 11:23 AM
thanks i'll try that
  #4 (permalink)
Old 11-13-2008, 03:57 PM
84-250 84-250 is offline
84-250 is gaining momentum as a positive member of FTE.
Unplug the ICP sensor in the front of the drivers side head. Also, when it dies, how long do you have to wait before it'll start again? What happens if you try to start it right after it dies?
__________________
1994.5 F350 CC PSD 5sp 4x4
T409 Downpipe & Cat Delete,6637, Valair 01HD Clutch
140V IDM, Pyro, Terminator Scangauge, Beans Tunes, Beans Stage 1s, Traction Bars
1984 F250 (RIP) PM me for parts
  #5 (permalink)
Old 11-13-2008, 06:02 PM
it will just crank and crank and when i first get it to start if you try to hit the gas it don't rev up at all it just idle then shut off and after it's start's it won't start again for a couple of hours and seem's to start if you unhook the battery's i also have another 99 f350 so i've tested the computer and it's ok then i swaped the IDM'S and it worked in the running truck but didn't change anything in the non running truck anything i'm missing
  #6 (permalink)
Old 11-13-2008, 11:39 PM
Would be nice to have the codes?If your cranking after it dies: is there any smoke, any noises?Kinda sounds like the IPR orings have split. IPR oring kit is $20 but a pain to get at the IPR
__________________
  #7 (permalink)
Old 11-13-2008, 11:43 PM
i'm not sure on the smoke can't see if it is and i don't here any sounds someone told to check the injectors to see if the plugs on them melted or if the wires are split
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
