I have a 1971 Ford F350. I need a new fuel tank and JC Whitney only sells as far back as 1973. The tank is a rear mounted tank. Will a 1973 tank fit my 1971?
Welcome to FTE
What do you mean by a rear mounted tank? Where is it mounted?
Is your truck a pickup with a Styleside bed, a Flareside bed, or?
1967/72 pickups all came with the in-cab fuel tank.
On Stylesides only, a 25 gallon mid-ship auxillary tank was available as an option.
Mid-ship = in front of the rear wheels, left side, mounted inside the frame rail.
There was no aft axle (behind the rear wheels) fuel tank factory installed till 1973.
Number dummy I had a 72 3/4 ton that never even had the hole in the body for the behind the seat tank. I thought it was weird so I looked pretty close the hole wasn't welded up. Only one I ever noticed though.
