Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-11-2008, 08:24 PM
hendedo hendedo is offline
hendedo is starting off with a positive reputation.
4.2L external coolant leak question
Hello all! Little history here before I begin.
99 F-150, 4.2L, auto, 150+K miles. New maf, and Motorcraft wires & plugs.
Truck runs well, BUT, noticing small coolant leak on the driveway. The tank goes down a inch or so after a day or 100 miles. Am finding coolant at the bottom of the bellhousing ( under the torque converter). Front of motor seems dry as do freeze plug on block side.
It is hard to see anything under this thing when I slide under.
Could it be a plug in the back of the head? Any ideas?
Thanks in advance.
  #2 (permalink)
Old 11-11-2008, 11:59 PM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE.
Hi and welcome to FTE! Glad ot have you here!
I reckon it could be coming from most anywhere. Earlier model years had problems with leaking lower intake manifold gaskets (which resulted in an internal leak) and sometimes a leaking timing chain cover gasket.
In your case, I'd check the front very closely, and look around the water pump (there is a weep hole that might be expelling some fluid)
Maybe it is leaking towards the front and getting blown to the rear?
There is a UV dye you can add to the coolant that will casue it to glow under a "black light". That might help find traces of coolant you might miss otherwise.
Good luck and let us know what you find.
Oh, and once again, welcome to FTE!
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
  #3 (permalink)
Old 11-16-2008, 05:48 PM
well, I looked under the truck. All the freeze plugs are dry. The water pump and fromt cover are dry. I started looking at the driver side head and it was dry. Then the passenger side. Hmm. Seems a bit of weepage around the back where the head mates to the block. There is even a drip seen. I pulled the oil dipstick and the oil is fine. Same with the oil filler cap; seems fine.
Now, is there a coolant passage on the outboard side of the gasket that would slowly drip but not mix with the coolant?
I priced a top end head gasket kit and if I get the head bolts too the price is about $225. That is for Fel-Pro.
Does this sound like what I need?
Thanks.
  #4 (permalink)
Old 11-17-2008, 10:00 AM
BrianA's Avatar
Sounds like you are on top of it.
Now just a matter of money, time and work ?
__________________
Brian A
Tags
2001 , 42 , 42l , coolant , f150 , ford , intake , leak , lower , manifold , v6 , water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
