460 carb problems
460 carb problems
Hey guys new to the forums and fords,I recently bought a 1987 F250,the guy I purchased it off put a new motor in and it ran great for a while but in the last couple days after the engine has come to temp and I kick it off high idle it idles fine but once I start driving and come to a stop it is ideling high again and this happens every time,I'm kinda a dummy when it comes to carbs so any ideas would be appreciated.
Thanks,
Tyler
Thanks,
Tyler
This is the place to answer your carb questions.
Holley Performance Technical Service Department
The choke butterfly valve needs to be adjusted and checked for proper operation. That will probably fix your problem.
