What do you put between body panels?
Ok I have a 79 Super Cab and the bottoms of both super cab sections near the rocker were cut out about 4-5 inches wide from the door to the back of the cab corner, by the PO and never replaced. So now there is surface rust between the body panels. My current plan is to sand blast off the rust as far as I can reach up between the body panels. The vac out the media, clean off the metal with a degreaser. Then apply Eastwoods rust converter, then rust encapsulator, weld thru primer the sharp edges. Then start welding in the patch panel and cover with some kind of putty (thoughts for a brand would be great??) Then cover with and epoxy primer till I do color some time next summer. Any thoughts, questions, suggestions would be great, this is my first run at doing body work
I would probably coat all the inside as you mentioned, then take the outside down to bare metal around the patch area. Once welded up and butts welds ground down. I would skim with Evercoat Zgrip, sand, and then epoxy prime. You can add more filler as needed on the epoxy primer. I would then coat with some 2K urethane primer and sand good before finish paint.
turnkyle
41
10-05-2014 02:02 PM
supercabfreak
16
08-10-2010 08:43 PM
