Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids and Mileage
Alternative Fuels, Hybrids and Mileage SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-10-2008, 03:33 PM
68f250360 68f250360 is offline
68f250360 is starting off with a positive reputation.
Duel Fuel Only Runs On One Fuel?
i have a 95 f250 4x4 7.5 running on propane or gas. due to gas prices i have been running it on propane, but now that gas has gone down i what to run it on gas but it wont switch over. i flip the switch and the thing just dies. so when the truck isnt running i turn the key on and off to "charge" the fuel system but nothing seems to work... the fuel rails are getting pressure, i check. i also check the fuel reset switch but that was fine. so i got out the test light and started to hunt down wires but i cant find the problem. i dont know if the gas went bad, i dont think so cause i added additives last time i filled up.
can someone help???
  #2 (permalink)
Old 11-25-2008, 03:30 AM
myv-879's Avatar
myv-879 myv-879 is offline
myv-879 is starting off with a positive reputation.
Possibly by not using Gas (petrol) something has dried out and is not operating. This used to happen to me in my carby 351 dual feul. I went through a feul pump and a carby kit because they dry out without feul going through them, Im now rebuilding it to run straight gas. What good does the gas (petrol) do anyway?
  #3 (permalink)
Old 11-25-2008, 01:52 PM
gasman6674's Avatar
gasman6674 gasman6674 is offline
gasman6674 is starting off with a positive reputation.
Check your fuel pressure and filter also check to see if your injectors are working
I am assuming your gasoline line does not have a fuelock (solenoid) that was installed when it was converted
__________________
Jim England
Do you have Gas?
Propane Execeptional Energy
If at first you don't succeed, redefine success
  #4 (permalink)
Old 04-24-2009, 02:31 PM
351M's Avatar
351M 351M is offline
351M is starting off with a positive reputation.
Could it be possible that something went wrong and the injectors have been running dry for awhile and died?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
