How to use manual 4x4
You can shift into & out of 4Hi anytime you want, though of course, if you haven't previously locked your hubs, 4Hi won't accomplish anything. You also wouldn't want to shift when you're in the process of spinning the wheels, or some other foolishness. No shifting into 4WD while you're spinning donuts.
The vehicle must be stopped when you shift into or out of 4Low.
And, yes, you can run it in 4Low with the hubs free. I've done so many times. You just need to be aware that the torque in 4Low is enough to put the rear end under stress if abused. I'm sure that Ford has a warning to that effect in the owners manual.
Yeah, use the 4-wheel drive at least once a month in both ranges, if nothing else roll it back in fourth in the driveway. There's guy's who don't engage the 4wd for years, they when they need it, the hub falls off or the shift motor don't work or the lever won't budge. It pays to keep it lubed up and operating as hydro_37 says. I've preached this for years on here. Stick around for our first major snow fall and you will see all the questions pop up on here why my 4wd isn't working. The reason is it's never used and the one time they need it, it's all gummed up and inoperable.
jchosler
10-06-2016 09:21 AM
