towing bronco II behind truck - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 11-10-2008, 10:56 AM
millertym_1978 millertym_1978 is offline
millertym_1978 is starting off with a positive reputation.
Question towing bronco II behind truck
looking for some info on using a tow bar for pulling my bronco II 4x4 to and from the deer lease? It is an automatic with a locked rear end. Is it even possible or do I need to keep using a trailer to haul it?
Thanks in advance,
Old 11-10-2008, 02:05 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
If I were going to do it that way I'd remove the drive shafts. This will reduce the wear and tear on the transmission and transfer case. If you don't want to go through all that hassle just drive it, or like you have been trailer it.
Old 11-10-2008, 02:42 PM
6CylBill's Avatar
6CylBill 6CylBill is offline
6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.
I would trailer it. Especially with that locked rear end. Just play it safe!
I'd rather be safe than sorry.
Old 11-10-2008, 04:38 PM
Thanks for the replies....
Old 11-10-2008, 04:51 PM
HappyJack's Avatar
HappyJack HappyJack is offline
HappyJack has a great reputation on FTE.HappyJack has a great reputation on FTE.HappyJack has a great reputation on FTE.HappyJack has a great reputation on FTE.HappyJack has a great reputation on FTE.
I don't know a whole lot about t-cases but I have flat towed vehicles and read some on this. I don't think you posted enough info on your truck or what you want to do ta say for sure. I'll give you my take on this and let you decide for yourself.
First the whole issue with flat towing or towing with the engine off is oiling. Different tranny's and t-cases are "oiled" differently. Many need the engine and/or tranny to turn to oil parts. Many of you know this but just in case some don't I wanted to put this in. Now the 1350 t-case has a pump in the back 1/2 that pumps oil to the front bearing. I have flat towed and have known folks who have flat towed and the common way used was to put the tranny in park or gear so the tranny parts do not move. If they don't move they don't need oil. Then shift the t-case into neutral. Now this is not true with all vehicles but is the most common and the way I did it with my early Bronco's and my friends have done it with BII's. Even then I have seen it recomended that you stop every 200 miles(or less) and start the engine so you "oil" stuff.
Now there are draw backs with flat towing. One is it is almost impossible to back up for any real distance and if you turn too sharp I have seen the front tires on the flat towed vehicle go to reverse lock (turn as far as possible in the opposite direction). And I don't know of a way to use the brakes on the flat towed vehicle from the towed vehicle. There may be something though.
I would not worry about the rear locker. It should not be a problem. The problem I can see would be weather or not you have a manual shift t-case and manual front lock outs. How far you will be towing and if you will need to backup. If you have a manual shift t-case then this is much more possible. Just put the tranny in park and shift the t-case in neutral. If you have an electric shift t-case then you have no way to shift the t-case into neutral. You can still still do this but would need to remove driveshafts. The rear for sure. And the front if you have auto front lock outs. If you have manual front lock outs just unlock them and your good to go either way.
I hope this helps some and good luck.
Old 11-10-2008, 04:56 PM
I have automatic with manual locking hubs and manual shift transfer case. Thanks for your help.
Old 11-10-2008, 06:14 PM
Bear River Bear River is offline
Former ******
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
Flat towing it would be a sure way to toast that tranny. The fluid pump is driven by the input shaft, so what you flat tow, the fluid is not being pumped. This causes the output bearing to run dry, and accelerated wear on both the bearing and the seal.
Old 11-10-2008, 06:28 PM
HappyJack's Avatar
Quote:
But if the tranny is in park and does not move there is no problem. If the t-case is in neutral and only the back half moves and the t-case has a pump in the back half for oiling there is no problem. I have flat towed many vehicles. Std. and autos and have never toasted a tranny or t-case because of it.
With his set up I would put the tranny in park, the t-case in neutral, make sure the front lock outs were unlocked and would not have any problem flat towing. I know people who have done this for years and have never had a problem.
The problem seems to be when folks don't have the t-case or tranny shifted properly. If the t-case is in gear then it will turn the tranny and can toast the tranny.
But if I had a trailer with good trailer brakes I would prefer that over flat towing.
Old 11-10-2008, 07:23 PM
Thanks for all the input. My trailer got wrecked so I'm trying to make sure I can tow it without doing any damage to it until I can buy another trailer. Thank you all for the info...
Anyone have a good website for ordering tow bars?
Old 11-10-2008, 09:10 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
Can I float gears in a 88 bronco ii 5 speed? MrCorter 1978 - 1996 Big Bronco 1 04-18-2016 12:06 AM
Why is a bronco II called a bronco II? mdr617 Bronco II 20 03-17-2011 12:01 PM
carbed 289 V-8 Bronco II mdr617 Bronco II 6 01-06-2011 07:17 AM
84 Bronco II Vacuum lines Loud4.9 Bronco II 3 10-24-2010 05:16 PM
floor shifter for an autmatic transmission bronco2man Bronco II 15 12-06-2007 01:32 AM
Tags
11, 85, bar, bronco, drive, f150, flat, ii, lockers, millertym1978, rear, removing, rv, shaft, tow, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
