Do you know brakes???
Old 09-03-2002, 09:16 PM
MustangGT221's Avatar
MustangGT221
MustangGT221 is offline
Old 09-07-2002, 07:49 PM
bubba4fl's Avatar
bubba4fl
bubba4fl is offline
Hey all,
I've got a 1980 F-100 2WD 4.9L
After replacing the front brake pads I lost some pedal (this due to bottoming the caliper to get the new pads in) so I bled them down. I took it for a drive and noticed that the right front wheel was hanging. I jacked it up and I could barely turn the wheel. I got it loose with a c-clamp and removed the caliper from the truck and took the piston out of the caliper. The seals, piston, and caliper all look good. No damage or obstructions. So I put it all back together and bled the front brakes down again and the same thing happened. The left front is OK so I'm pretty sure it's not a broblem with the master cylinder. Now I'm stumped. Can anyone offer advice or have you had this problem. Thanks - BUBBA
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Do you know brakes???
