Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids and Mileage
Alternative Fuels, Hybrids and Mileage SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-10-2008, 04:55 AM
Opossum's Avatar
Opossum Opossum is offline
Of Your Rights
Opossum is gaining momentum as a positive member of FTE. Opossum is gaining momentum as a positive member of FTE.
Lightbulb Ammonia Fuel
Have any of you guys looked into ammonia as a fuel or additive.
A gallon of anhydrous ammonia has more hydrogen than a gallon of liquid hydrogen.
It's cheap and abundant.
Rather combustable there's many differant engines that have been powered with ammonia from cars to jets.
It very readily absorbs in water, and apparently can be mixed with gasoline/deisel.
I was thinking a good first step would be and ammonia injection system much like water/methonal injection using an ammonia/water mix.
Thoughts?
__________________
As to the species of exercises, I advise the gun. While this gives moderate exercise to the body, it gives boldness, enterprise and independence to the mind. Games played with the ball, and others of that nature, are too violent for the body and stamp no character on the mind. Let your gun therefore be your constant companion of your walks.
--Thomas Jefferson
  #2 (permalink)
Old 11-11-2008, 02:13 PM
dchamberlain dchamberlain is offline
dchamberlain has a very good reputation on FTE. dchamberlain has a very good reputation on FTE. dchamberlain has a very good reputation on FTE. dchamberlain has a very good reputation on FTE.
My Dad used to work with Anhydrous Ammonia as a fertilizer. The stuff is pretty dangerous. You needed special licenses and training to work with the stuff. If you had a large spill, or a blown line or blown tank, your only hope was to get to the emergency shower in the 20-30 seconds before it killed you.
Using Anhydrous Ammonia Safely on the Farm
__________________
David Chamberlain
2004 F-250 SD, 4x4 FX4, 6.0L PSD
Oregon Chapter Member:
To join the Oregon Chapter, click HERE
  #3 (permalink)
Old 11-11-2008, 02:23 PM
Opossum's Avatar
Of Your Rights
A solution in water is rather safe.
__________________
--Thomas Jefferson
  #4 (permalink)
Old 11-11-2008, 09:01 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE.
water doesn't burn very well last I checked...
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #5 (permalink)
Old 11-12-2008, 12:06 AM
AspenF150's Avatar
AspenF150 AspenF150 is offline
AspenF150 is starting off with a positive reputation.
Quote:
my thoughts too
  #6 (permalink)
Old 11-12-2008, 12:20 AM
Opossum's Avatar
Of Your Rights
Fine stick with your HHO scam.
__________________
--Thomas Jefferson
  #7 (permalink)
Old 11-12-2008, 01:30 AM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
Quote:
Yes, I thought about, but it's less than ideal, even though it's one of the few fuels that can be had and used without any greenhouse gas emission. Another is hydrazine (N2H4), which is actually used as a rocket fuel.
Do you know what's needed to make concentrated ammonia on an industrial scale? Nitrogen, which is plentiful in the air, and hydrogen, which is usually made of natural gas. You'd better of burning CNG than making NH3 from it, and then trying to burn that.
Quote:
Rather combustible there's many different engines that have been powered with ammonia from cars to jets.
I haven't heard any engines powered with it, so it's probably not very common, and there are some good reasons for that, with one of the mbeing:
"Ammonia does not burn readily or sustain combustion, except under narrow fuel-to-air mixtures of 15-25% air. " (this is from Ammonia - Wikipedia, the free encyclopedia )
Other one s that concentrated ammonia can be rather deadly, much more dangerous than either gasoline or hydrogen.
The water part is most certainly true, but I'm somewhat (?!) skeptical about the other two.
Just get a water injection kit, and put in ammonia instead of water.
At least they don't stink as much as NH3....
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
