Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-09-2008, 10:02 PM
berg87 berg87 is offline
berg87 is starting off with a positive reputation.
A must read for all with 4.2/3.8 questions
The 3.8L Motor - V6Power Messageboard
I highly recommend reading this thread about the history and development of the Ford 3.8L and 4.2L
its a bit long but hang in there, some very good information. After reading this i have a whole new found respect for this (these) engines.
I always thought the 3.8/4.2 was a 5.0Lv8 minus to cylinders, I was wrong.
hope the information in this tread is helpful for everyone.
  #2 (permalink)
Old 11-16-2008, 03:43 PM
mustangman02232's Avatar
mustangman02232 mustangman02232 is offline
mustangman02232 is starting off with a positive reputation.
ive actually known this for a while... there damn good engines, they copied alot but ford made the block on-center, unlike buicks, and ford used aluminum heads to buicks cast iron, which in turn, dont hold heat as much and can be ported like a mofo. no one even makes aftermarket blocks for the "essex" motors, right now, 800 HP has been gotten out of them with just forged pistons and rods (stock block and crank)... i dont think it will be to long before we see 1000 HP out of a essex unlike sayyy a 302 which will split down the lifter vally at ~450 HP... watch out supra guys
these are the stock "crappy" single port heads that have only been ported those outflow even ~$3k AFR aftermarket 5.0 heads
my single port Flow #s - 3.8 Mustang Message Board
article
REBUILDING THE FORD 3
the ford 3.8 is probably THE most underestimated motor ever, im hoping for ~500 when my stang is set in complete (wont be for a few years) by running a 4.3 (4.2 with .030 bore) and a 9.1ish:1 CR with ported heads, cam, and a nice ole 2.3 whipple on top should be able to do it for less then 10k WITH the supporting mods
they can also be VERY reliable engines
http://www.mustangforums.com/forum/s...d.php?t=431477
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
