whats a 10K mod and ICP MEAN
Here's a link to the 10K mod. This just one of many ways to do it.
Some run 14.7K resistors or even higher. Each engine responds differently the mod.
Ford Powerstroke 10k Mod
The 10k mod is added to the IPC (Injection Pressure Control) sensor.
It tricks the computer on the truck to supply a higher pressure to the injectors
effectively giving the fuel a little extra kick into the cylinder.
On a completely stock truck, it should be good for about 30HP and 100 lb/ft of Torque
If you have any chips or tuners, the effect will be slim to none as the ICP is already
being modifed by the chip/tuner in most circumstances.
