'60 Bench seat replacement.
Old 11-07-2008, 02:08 PM
Luddle's Avatar
Luddle
Luddle is offline
So i searched and could not find a thread that specifically answered my question; what vehicles could I take a bench seat out of that would fit a '60 pretty well? The original needs to be redone completely and I just don't have that kind of cash.
Old 11-07-2008, 04:17 PM
52 F3's Avatar
52 F3
52 F3 is offline
This is copied from the sticky at the top of the forum. Maybe you have already seen it. If not there is a lot of seat info here.
<TABLE class=tborder id=post5537364 cellSpacing=1 cellPadding=6 width="100%" align=center border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD class=thead itxtvisited="1">01-06-2008, 12:41 PM <!-- / status icon and date -->
</TD></TR><TR itxtvisited="1"><TD class=alt2 style="PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; PADDING-TOP: 0px" itxtvisited="1"><!-- user info --><TABLE cellSpacing=6 cellPadding=0 width="100%" border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD class=alt2 itxtvisited="1"></TD><TD noWrap itxtvisited="1">Fomoko1 ******** type=text/javascript> vbmenu_register("postmenu_5537364", true); *********>
</TD><TD width="100%" itxtvisited="1"> </TD><!--<td width="100%" style="padding-left:25px;"></td>--><TD vAlign=top noWrap itxtvisited="1">Join Date: Dec 2003
</TD></TR></TBODY></TABLE><!-- / user info --></TD></TR><TR itxtvisited="1"><TD class=alt1 id=td_post_5537364 itxtvisited="1"><!-- message, attachments, sig --><!-- icon and title -->Seat info
<HR style="COLOR: #d1d1e1" SIZE=1 itxtvisited="1"><!-- / icon and title --><!-- message --><TABLE width="100%" border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD vAlign=top itxtvisited="1">An excellent article by ferguson777 I`m reposting here, it`s also part of the above link https://www.ford-trucks.com/article/i...rd_Trucks.html
__________________________________________________ ___
Here are some measurements that you might want to consider when looking for a new seat.
· Inside cab width from door panel to door panel (where the seat bottom is the widest)
o 1948-1952 F-1 = 53.5 inches
o 1953-1956 F-100 = 58 inches
· Distance between the door handle tips
o 1949 F-1 = 51.5 inches
· Distance between the fat part of the door handles
o 1949 F-1 = 45-5/8 inches
· Distance across the cab at the rear door post
o 1949 F-1 = 57 inches
· Distance from door panel to door panel
o 1957-1960 F-100 = 62 inches
· Distance from door handle to door handle
o 1957-1960 F-100 = 56 inches
· Stock bench seat width
o 1960 F-100 = 59 inches
There seems to be an issue (particularly found by older members of the forum) with the space between the steering wheel and the seat shrinking over time, resulting in limited intestinal accommodation. Fortunately the newer seats use a different type of spring so they tend to be thinner in the back. This provides more room in that area. This is something to think about before you buy a big, fat seat out of a Cadillac or Lincoln or some other land yacht. With a newer seat, you will usually pick up storage space under the seat bottom as well.
The following suggestions are based upon input from this forum. There is also an article in the August 2004 issue of Classic Truck that deals with this subject and contains many pictures of the suggested alternative seats. Note that we are not spending time discussing bucket seats. Once you ditch the console, you can pretty much fit any bucket into any truck, although generally you’ll end up with a built in headrest sticking up in your back window.
1948-1952 Trucks – Seat Width No More Than 52 Inches
· 2000 Ford Escort buckets
· Mid/late 1980s to 1996 Ford Ranger or Broncos
o 60/40 bench or buckets
o Perfect fit
o Used by many
o Bench is 51” wide at it’s widest point
o Back folds forward
o No headrests to poke up in the back window
o 2-door donors fold, 4-door donors don’t
o Very popular with members of the forum
· 1989 through mid 1990s Ford Explorer
o Buckets or 60/40 bench
· Middle or rear seats out of a 1996 Dodge Caravan
· 1996 and newer Chevy Astro Van
· 1996 and newer full sized GM van middle or rear seats
· 1995 and newer Toyota Tacoma
· 1994 and newer Chevy S-10/Sonoma
1953-1960 Trucks – Seat Width No More Than 58 Inches
· 2001 F-150
NOTE: There are several different styles of bench seats used in the late 1980s through late 1990s GM trucks – quasi-buckets, 60/40s and full benches. They all tend to have thin backs which helps to increase leg space where needed. Some have built in arms rests and a level of seat bottom sculpturing to them, some don’t. These seats are also well liked by a number of the members of this forum.
· 1988-1998 GM truck seats
o Excellent looking brackets
o Easy to adapt
o Headrests tend to be removable
· 1988-1994 Chevy Silverado bench
o No headrest
o Fold down arm rest
o Very stylish
· 1997 and newer F-150 bench
o Has a built in headrest
o Brackets are a bit of a challenge
· Late 1990s Chevy Suburban
· 1987 Chevy pickup bench
· The 2000 and newer Suburban
o 60/40 bench
o Removable headrests
o Not the most stylish thing
o Brackets are clunky looking
The 1999 and newer GM Silverado 40/20/40 “bench” is an interesting possibility. It’s 60 inches wide, but it’s really more like two buckets with a “jump seat” between. You could easily omit the middle section and put in a narrower console or nothing. They do have built shoulder belts, saving you the issue of mounting the shoulder restraint to the wall between the rear window and the doors. You might fit this whole set up into a 1953-1960 F-100. The 1994 through 2001 Dodge truck also has a similar set up, though less stylish than the GM version. It will have the same pluses and minuses.
Another issue to consider is that you need to build some sort of bracket to mount your new seat(s) to your truck. If you’re using the 1988-1998 GM seats, it’s pretty straightforward. Just look at the stock GM mounting brackets and it’s a no brainer. However, if you’re using Ford seats or buckets, this can get a little tricky. For a few good pictures of the brackets one member made to install a later model seat check out this thread. https://www.ford-trucks.com/forums/sh...d.php?t=114729 The work was done by KAI - our German buddy. He was putting a 1980 F-350 seat in a 1954 F-100. His brackets deal quite nicely with the weird bend/angle in the front of the stock Ford brackets. They are wonderful in their simplicity and could easily be modified to compensate for a shorter driver.
For an excellent example of brackets fabricated to hold the 1996-2000 Ranger 60/40 bench/bucket, check out those made by Scott123 (Scott Jones). He has provided pictures and plans, so you could make a copy of the “Scott123 Super-Duper seat frame 2000” if you wish.
Check out their galleries for the pictures/plans referred.
</TD></TR></TBODY></TABLE><!-- / message --><!-- sig -->__________________
Fomoko1..Morris
Chapter Leader Manitoba/Saskatchewan
1927 Model T Touring
56, 57 & 71 F350
53 & 56 M100
98 Ranger XLT s/cab
92 F250 XLT supercab 4X4
2005 F350 6.0 4X4 Lariat Crew
65/67 Mustang Fastbacks
57 Ford 800 tractor
86 & 88-LN 8000 Ford trucks
<!-- / sig --><!-- edit note --><HR style="COLOR: #d1d1e1" SIZE=1 itxtvisited="1">Last edited by Fomoko1 : 01-09-2008 at 01:08 AM.
Old 11-07-2008, 05:34 PM
Luddle's Avatar
Luddle
Luddle is offline
Ah, thank you! I guess I didn't look hard enough.
Old 11-20-2008, 03:34 PM
Bobs55effie's Avatar
Bobs55effie
Bobs55effie is offline
I remember reading an article about Buick Lesabre being a good seat for 53-56 trucks. They have integrated seat belts. Does anyone have an opinion on these seats, their brackets, or other seats?
Old 11-20-2008, 03:55 PM
52 F3's Avatar
52 F3
52 F3 is offline
I think the fit would probably be good. You would not have a tilt back for access behind the seat though.
I noticed the seat in a 2002 DeVille the other day and it measured the right width plus had the shoulder belts in the seat. Nice leather seat but no tilt back.
A guy needs to make a trip through the salvage yard with a tape measure. I think there would be a lot of good candidates.
dferrell5
08-21-2014 06:40 PM
ireding
03-26-2014 09:34 PM
wresleu
1983 - 2012 Ranger & B-Series
10-03-2013 09:02 PM
Cyco CK
WTB - Parts & other
09-29-2012 04:10 AM
Matt96Ranger
12-11-2005 08:32 PM
Quick Reply: '60 Bench seat replacement.
