Replacing the Transfer case fluid - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-07-2008, 08:14 AM
flyingtexan's Avatar
flyingtexan flyingtexan is offline
flyingtexan is starting off with a positive reputation.
2008 F250 V10
My manual states "Ford Transfer Case Fluid" is the fluid to use...what a shock. Anyone know what a Mobil Synthetic equivelent would be for my 08 SD?
Thanks
Old 11-07-2008, 10:10 AM
brian42's Avatar
brian42 brian42 is offline
brian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to behold
Quote:
Originally Posted by flyingtexan View Post
2008 F250 V10
Thanks
The transfer case in my '03 uses a little over 1/2 gallon of ATF so I don't know what is referred to as transfer case fluid, but here's a bump for ya.
Old 11-07-2008, 10:26 AM
03_PSD 03_PSD is offline
03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.
i put mobile 1 atf syn. in mine, works great!
Old 11-07-2008, 10:56 AM
gofast51004's Avatar
gofast51004 gofast51004 is offline
gofast51004 is starting off with a positive reputation.
Quote:
used the same, no issues
Old 11-07-2008, 01:13 PM
WestxSRT10's Avatar
WestxSRT10 WestxSRT10 is offline
WestxSRT10 is starting off with a positive reputation.
I called my buddy at Ford parts dealership......Mercon 5 for the 08's transfer cases, holds about 3.5 qts better get 4 qts.
Old 11-07-2008, 01:37 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
Mercon 5 is an ATF so any ATF that is Mercon compatible/comparable is good. I replaced mine with Royal Purple since I had plenty on hand.
Old 11-07-2008, 02:15 PM
RckyMntnKng's Avatar
RckyMntnKng RckyMntnKng is offline
RckyMntnKng is starting off with a positive reputation.
All i can say is....before you drain the darn thing, have the right size Allen wrench to remove the fill plug.
Old 11-07-2008, 03:56 PM
brian42's Avatar
Quote:
Originally Ford said that you could not use Mercon V in Mercon recommended systems. Since Mercon is no longer being produced, only Mercon V rated ATF, Ford has since issued a bulletin stating the Mercon V is compatible to Mercon and can be used instead of Mercon.
Old 11-07-2008, 05:17 PM
ReAX's Avatar
Right, now mercon is mercon and mercon V.
Old 11-07-2008, 05:59 PM
WestxSRT10's Avatar
Yes.... but Mercon V is not used in the new automatic transmissions! that would be Mercon SP. Looks like Ford has 5 differiant auto transmission fluids now.
Old 11-07-2008, 06:09 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Quote:
I never understood that myself. M1, Amsoil and others can make a universal synthetic ATF but were still screwing around with different grades.
Old 11-07-2008, 06:28 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow
2008 F250 V10
Thanks
Just a friendly TIP: Make sure to drive around and get the transfer case to normal operating temp. That is the best way to change it out...just because it flows better.
Agree with the other posts...any Mercon V will do. I like OEM FORD...but that is just my preference...
biz
Old 12-15-2011, 09:24 AM
Tennesseepowerstroke Tennesseepowerstroke is offline
Tennesseepowerstroke is gaining momentum as a positive member of FTE.
A notation on the back of the Motorcraft Mercon V bottles says "Do not use in transfer cases". My 03 manual says to use Mercon ATF which is not longer made.
Old 12-15-2011, 10:44 AM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
In 2008, Ford changed to "Ford Transfer Case Fluid." I've never found a good explanation of why or what the difference is or if there is even a difference in the transfer case from earlier models.
Frankly, though, for the cost of 3 quarts of fluid from Ford, vs the cost of a transfer case, I'd get the stuff from Ford.
Old 12-15-2011, 12:17 PM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
I would not use Motorcraft Mercon V in my transfer case, because the bottle specifically says not to. Does anyone think they were joking?
When Ford obsoleted the Mercon, and interchanged Mercon V, evidently they had a problem because Mercon V was not suitable for transfer cases. That is when they released a product specifically called Transfer Case Fluid. I don't believe they came up with a new product SKU just for the heck of it. There had to be a good reason why their Mercon V was not to be used in TC.
I would skip the Motorcraft product altogether. I used Mobil 1 synthetic ATF in my TC and it has been perfect for a long time. Buy 3 quarts. You might need only 2, but many take a bit more. Return the 3rd one if you don't need it. Or save it for the day when you flush your power steering system. It works great for that too.
2012 transfer case fluid types what do you use fishbones182 1999 to 2016 Super Duty 3 12-30-2015 08:24 AM
Transfer case fluid ? Andy Sullivan 1994.5 - 1997 7.3L Power Stroke Diesel 8 02-15-2014 05:52 PM
Transfer case fluid question FixinOlBlackie 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 11-08-2013 11:02 AM
Fluid amount in C6 and transfer case? kcode 1973 - 1979 F-100 & Larger F-Series Trucks 3 12-30-2011 09:19 PM
transmition and transfer case fluids mklemin 1994.5 - 1997 7.3L Power Stroke Diesel 3 05-07-2008 03:31 PM
Tags
1999, 2001, 2004, 2005, case, f150, f250, f350, fluid, ford, oil, purple, royal, transfer, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
