Replacing the Transfer case fluid - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-15-2011, 02:26 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
After reviewing the design of the transfer case, I'm now thinking the "no Mercon V" and the introduction of TC fluid is entirely marketing BS. I can not see anything in the TC that would require a "unique" fluid. Or that would be incompatible with a different fluid.
It's just roller bearings and a chain. No clutches, temperature extremes, tight bearing clearances, hypoid gears, etc. Any lightish lubricating oil should be adequate. Heck, even gear oil would probably be fine - at some cost to mpg due to drag.
Anybody see something I'm missing?
Old 12-15-2011, 02:31 PM
dchamberlain's Avatar
dchamberlain dchamberlain is online now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
Quote:
Originally Posted by mwsF250 View Post
No clutches
There is a dual cone synchronizing clutch on the front drive-shaft gears. It is what spins up the front drive shaft before the actual gears can mesh.
Beyond that, you are probably right. Thing is, for some reason in 2008 they decided to switch to the Motorcraft Transfer Case fluid. Did they change something? I don't know. Is it worth the price of three quarts of fluid to find out?
Old 12-18-2011, 02:27 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow
...when FORD makes changes...I'll go with the recommended change. Had to do that with the tranny fluid...so no reason not to go with it on the transfer case.
Just my .02.........
biz
2012 transfer case fluid types what do you use fishbones182 1999 to 2016 Super Duty 3 12-30-2015 07:24 AM
Transfer case fluid question FixinOlBlackie 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 11-08-2013 10:02 AM
1350 transfer case fluid? Help I M Stuck Bronco II 4 05-28-2008 12:56 AM
transfer case B1GKAHUNA 1999 to 2016 Super Duty 2 03-25-2007 10:27 AM
what is the right fluid for the transfer case? djmac Clutch, Transmission, Differential, Axle & Transfer Case 10 07-01-2004 01:11 AM
Tags
1999, 2001, 2004, 2005, case, f150, f250, f350, fluid, ford, oil, purple, royal, transfer, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
