Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Appearance & Dress-Up SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2008, 10:43 PM
earnhardtracer38 earnhardtracer38 is offline
earnhardtracer38 is starting off with a positive reputation.
7 year old oxidation
I bought a 84 Bronco II that was sitting for seven years. The paint has really oxidized in that seven years of not moving. I have tried rubbing compound on some spots and it seems to take more of thecolor off than the oxidation. Then I got a wild idea and tried some mag/aluminum polish on it. That worked out great in the spot that I did. No paint coloring came off and the paint was smooth. The thing is though, I dont have enough to do the whole vehicle. Whats the best way to go about getting rid of this? It doesnt have to look perfect since its an off roader, but I dont want to keep the dullness of it now. I would like a little shine on it.
  #2 (permalink)
Old 11-07-2008, 01:42 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE.
I would go with the clay bar first. Old style rubbing compounds are good on enamel paints but aren't designed for clear coat paint. Mag/Alum is very abrasive compared to non-commercial paint cleaners. start as light as possible and move to more abrasive compounds as you have too. The clay bar isn't very abrasive, it mostly just sticks and pulls.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #3 (permalink)
Old 11-07-2008, 02:24 PM
skaterbro's Avatar
skaterbro skaterbro is offline
skaterbro is starting off with a positive reputation.
Yeah, i too will say clay it. It won't do anything for the oxidation, but it will smooth out the surface and give you a good starting point.
I would go:
-Wash
-Clay
-Paint cleaner
-Polish
-Wax
The third step is where you'll remove most of the oxidation. If you have a DA, you'll see much better results. But doing it all by hand will also yield good results. A day's worth of work and your Bronk could be shiny again.
__________________
93 F-150 XLT, 302, E4OD
  #4 (permalink)
Old 11-18-2008, 10:28 PM
ClydeSDale's Avatar
ClydeSDale ClydeSDale is offline
ClydeSDale is gaining momentum as a positive member of FTE.
Cllyde was heavily oxidized when I found it .... more than twelve years worth of oxidation. I don't think it ever saw a wax job and I do believe the wash jobs were few and far between. I used Mequires three step process and a relatively inexpensive random buffer. When you squirt the cleaner on DON'T let it set too long before you spread it with the buffer. Don't ask me why I know this!
This is the second paint job revival I've done with Mequires. The first was a Laguna Blue '94 Miata that was totally flat! You couldn't even see the reflection of your hand in the paint, when I got done you could see the wrinkles on your knuckles!
No "before's", but here's an "after".
With the exception of the back of the cab (PO's damn topper boot) everything above the lower chrome trim is OE.
__________________
Roger
Clyde S Dale, Camper Pulling Workhorse
1984 F250HD XLT RCLB 4X2 8600 GVW 460 ^Timing C6 Track-loc 4.10's
Trailer Towing/Camper Pkg K&N in/DynoMax out All synth fluids, fully temp gauged
4-core HeatbusteR radiator, dual OE plate type tranny coolers 74,000 original miles (and counting)
ClydeSDale Photo Album
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
