Seat cushion for bench seat
I provided some advice to fix in your previous post on seat sag and broken spring.
"You can reinforce the springs, or you can take the seat cover off and have some firmer replacement foam cut and inserted in your seat foam at your local auto upholstery shop."
I also stated you should be able to have your broken spring welded back. Please read all the responses on your last post.
If you'd rather 'do-it-on-the-cheap',you can get pillow forms at your hobby shop, they are pre-form foam and you can inset as many of those as it may take to fill in the space of the seat that needs repaired. Then get a good, medium-priced bench seat cover to put over your work , what ya' think? ( I have used ' poor-boy ingenuity' for years )
jminor
15
05-01-2014 09:24 AM
mechelement
12-31-2008 01:37 PM
